Spot the deliberate mistake |
Post Reply | Page <1 30313233> |
kedwardsleisure
Mm..been a while with me and these things. The last nightclub client that used them is now a housing estate. Loose fuse clips, arcing mosfets, leaky driver transistors will all make unwanted noises on these. Earlier versions with LCR capacitors can leak electrolyte underneath them and cause the pins to arc, though ISTR its less of a crackle and more of a bang. Yours looks fairly new as it has Samwha capacitors. (all things being in perspective) |
North Staffordshire |
EmPro
Young Croc Joined: 26 June 2020 Status: Offline Points: 766 |
i changed the capacitors from old LCR to new samwha,remade all the solderings and added small heatsinks on the drivers as they get bloody hot in these things and make all sort of funny noise into speakers ,no problem since.
EmPro Audio
Andylaser
Registered User Joined: 16 April 2010 Location: Southampton Status: Offline Points: 300 |
Knowing those old BK amps, something very easy to fix.
"music so loud, that if we move in next door to you; your lawn will die" - Lemmy
EmPro
Indeed,10min if you have the parts you need,the hard part is that you need to remove the module out of the case if you need to change parts as no acces underneath because all the body case is basically heatsink for the mosfets,and that takes time
Edited by EmPro - 28 May 2022 at 2:55pm |
EmPro Audio
kedwardsleisure
Cloud VX-A4.
'It's been serviced regularly every 12 years.' |
EmPro
After or before Christ?
EmPro Audio
jazomir
Old Croc Joined: 20 November 2006 Location: Sunderland UK Status: Offline Points: 1710 |
Bears an uncanny resemblance to the innards of my daughter's old laptop - keyboard crud doesn't begin to describe the carnage the PC repair guy found when he opened it up.
kedwardsleisure
Marshall JCM800 Jubilee Special. Client reports making strange crackling noises.
Edited by kedwardsleisure - 10 February 2023 at 9:27am |
MattStolton
I like my solder joints, like I like my Martinis, "Dry".
However, that isn't just "dry", more "absent"?
kedwardsleisure
Can't blame the chinese this time as they're made in the UK. I suppose the girl wiring it could've had something on her mind, although you'd think QC would've picked it up. At least it wasn't an earth.
Lucasdude
Young Croc Joined: 16 March 2013 Location: London Status: Offline Points: 823 |
Didn't we cover this "wrap around the pole" termination technique last year?
kedwardsleisure
Haven't had one of these for a while so as it's a Friday...
Not specifically speaker related but a ubiquitous Meanwell 600W power supply. Client installed one in his enclosure and it went bang. Bought another and installed that, it went bang too. Very unusual as Meanwell are a pretty decent product in my experience. A photo of my recently made pot noodle for the correct guess. |
