Spot the deliberate mistake |
Page <1234 32> |
brokenjoe ![]() Old Croc ![]() Joined: 31 May 2009 Location: Birmingham Status: Offline Points: 3712 |
i found someone using a drill bit once..
nearly killed myself touching it at the back of his rack
error 404
KidCreole ![]() Old Croc ![]() ![]() Joined: 06 November 2013 Location: London (East) Status: Offline Points: 3599 |
Doing an impersonation of Eric Morecambe?
Mykey Wattco
DMorison ![]() Old Croc ![]() Joined: 14 March 2007 Location: Aberdeen Status: Offline Points: 1550 |
Fцck
me, I’d heard stories about that happening but never believed they were
anything but apocryphal! Surely whoever does that must be shortlisting
themselves for Darwin Awards |
Kobe ![]() Registered User ![]() Joined: 13 July 2007 Status: Offline Points: 120 |
manufacturer fault on a brand new from the factory Gemini PL02 PDU (clue - the whole chassis was tingly to the touch!!) |
Pinyorouk ![]() Young Croc ![]() Joined: 31 January 2011 Status: Offline Points: 525 |
Neutral or live was connected to the Chassis? as blue wire that goes to the ground common is not going to the IEC ground pin? Can also see a green and blue cable to the chassis earthing point if that is relevant.
odc04r ![]() Old Croc ![]() ![]() Joined: 12 July 2006 Location: Sarfampton Status: Offline Points: 5483 |
Hmm, going on that chassis bolt earth and neutral connected there?
Earplug ![]() Old Croc ![]() Joined: 03 January 2012 Location: Europe Status: Offline Points: 6911 |
That´s what´s called a fatal mistake. Horrible.
kedwardsleisure ![]() Old Croc ![]() Joined: 20 January 2009 Location: Staffordshire Status: Offline Points: 4759 |
Maybe the person who did the PAT testing at the end of the production line had flu that day.
North Staffordshire |
This Dynacord Powermate 1000 came from another dealer, it had been repaired by AN Other and not lasted long.
ceharden ![]() The 10,000 Points Club ![]() ![]() Joined: 05 June 2005 Location: Southampton Status: Offline Points: 11682 |
To a first glance, it looks horrible because they've mixed devices but on second thoughts they've probably replaced the whole of one side of the bridge so it's not s bad. However, are they all genuine OnSemi. Or am I missing something that I can't see clearly on this size image?
On third thought, I think I can just make out a mix of 15022's and 15024's on the bottom right quadrant.
_djk_ ![]() Old Croc ![]() Joined: 23 November 2004 Location: United States Status: Offline Points: 6002 |
One of the devices on the bottom sink looks like a fake.
djk
Indeed, bit odd that the printing on that one is horizontal and the rest and vertical.
Page <1234 32> |
