Spot the deliberate mistake |
Post Reply | Page <1234 33> |
brokenjoe
Old Croc Joined: 31 May 2009 Location: Birmingham Status: Offline Points: 3722 |
i found someone using a drill bit once..
nearly killed myself touching it at the back of his rack
error 404
KidCreole
Old Croc Joined: 06 November 2013 Location: London (East) Status: Offline Points: 3600 |
Doing an impersonation of Eric Morecambe?
Mykey Wattco
DMorison
Fцck
me, I’d heard stories about that happening but never believed they were
anything but apocryphal! Surely whoever does that must be shortlisting
themselves for Darwin Awards |
Kobe
Registered User Joined: 13 July 2007 Status: Offline Points: 120 |
manufacturer fault on a brand new from the factory Gemini PL02 PDU (clue - the whole chassis was tingly to the touch!!)
Pinyorouk
Young Croc Joined: 31 January 2011 Status: Offline Points: 551 |
Neutral or live was connected to the Chassis? as blue wire that goes to the ground common is not going to the IEC ground pin? Can also see a green and blue cable to the chassis earthing point if that is relevant.
odc04r
Hmm, going on that chassis bolt earth and neutral connected there?
Earplug
That´s what´s called a fatal mistake. Horrible.
kedwardsleisure
Maybe the person who did the PAT testing at the end of the production line had flu that day.
North Staffordshire |
kedwardsleisure
This Dynacord Powermate 1000 came from another dealer, it had been repaired by AN Other and not lasted long.
ceharden
To a first glance, it looks horrible because they've mixed devices but on second thoughts they've probably replaced the whole of one side of the bridge so it's not s bad. However, are they all genuine OnSemi. Or am I missing something that I can't see clearly on this size image?
On third thought, I think I can just make out a mix of 15022's and 15024's on the bottom right quadrant.
_djk_
One of the devices on the bottom sink looks like a fake.
djk
odc04r
Indeed, bit odd that the printing on that one is horizontal and the rest and vertical.
