Forum Home Forum Home > Buying and Selling > Wanted
  New Posts New Posts RSS Feed - square stage legs , couplers
lickweed View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote lickweed Quote  Post ReplyReply Direct Link To This Post Topic: square stage legs , couplers
    Posted: 22 November 2020 at 11:02pm
40x40mm x1000mm plus legs couplers
http://www.liquidsound.co.uk/
csg View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote csg Quote  Post ReplyReply Direct Link To This Post Posted: 23 November 2020 at 8:17am
Steel or aluminum? Probably steel for that height as the cross section is not large
Post Options Post Options   Thanks (0) Thanks(0)   Quote lickweed Quote  Post ReplyReply Direct Link To This Post Posted: 23 November 2020 at 1:48pm
either ,its for dj stand etc... not heavy load
Post Options Post Options   Thanks (0) Thanks(0)   Quote lickweed Quote  Post ReplyReply Direct Link To This Post Posted: 02 June 2021 at 9:38pm
still looking
imageoven View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote imageoven Quote  Post ReplyReply Direct Link To This Post Posted: 03 June 2021 at 12:36am
How many do you need? Its generally cheaper to get them cut by a metal supplier and put the feet in yourself. If its just a few, probably best to cut them yourself if you have access to a cut off saw (not expensive). Don't cut them at an angle with a hacksaw....
Post Options Post Options   Thanks (0) Thanks(0)   Quote lickweed Quote  Post ReplyReply Direct Link To This Post Posted: 23 November 2021 at 3:03pm
still looking
Post Options Post Options   Thanks (0) Thanks(0)   Quote imageoven Quote  Post ReplyReply Direct Link To This Post Posted: 23 November 2021 at 5:06pm
lots of steel box section in the world, no need to get it posted to you Im sure.
