Stacking 1850's with Looneys's |
Pav
Registered User Joined: 22 August 2009 Location: Oxfordshire Status: Offline Points: 243 |
Posted: 26 September 2009 at 7:19am |
I've some 1850's and am about to get some looney's. The 1850's are loaded with PD's and the looney's v1000's. Can you stack the together and would you cross them all over at the same point?
Cheers Edited by Pav - 26 September 2009 at 7:20am |
toastyghost
Yes and yes, it won’t sound quite as good as having all 1850s or all Looneys but the Looney is a tweaked version of the 1850 horn and sounds similar enough that most people won’t notice when stacked together.
You may need to give the 1850s a little more gain to keep up with the Looneys though, as the tweaks gained up to 3dB more output across the frequency range. |
