staiper micro scoop question |
hmaudio
Old Croc Joined: 03 April 2009 Location: Nottingham Status: Offline Points: 3844 |
Posted: 28 August 2011 at 3:20pm |
what exactly does this part do?
iv built 4 and iv not put that part on
This account is used by 2 people. |
eltron
Registered User Joined: 21 December 2007 Location: Finland Status: Offline Points: 399 |
It forms the throat. Notice the 110 mm measurement on the left!
Look at the super scooper plan for instance, you'll find the so called "dog leg" on it also. Edit: I missed the last part of your post: If you left it out the throat has theoretically moved downwards in the horn (technically to the narrowest point), thus making the back chamber bigger and horn shorter.
Edited by eltron - 28 August 2011 at 8:37pm |
mobiele eenheid
Old Croc Joined: 15 August 2004 Location: Netherlands Status: Offline Points: 1568 |
Personally I'm not sure whether it will give you any noticeable difference (to your hearing that is). You could however glue it in there through the speaker cutt out, if you make it in two halves (in the length).
Best regards Johan
hmaudio
Thanks for the replies, il get some made up and see if i can hear any difference,
cheers Adam
phildat
Young Croc Joined: 29 January 2009 Location: manchester Status: Offline Points: 1115 |
Looks like it ensures positive expansion throughout the design.
Its just a ride.
MINTEVENTRESOURCES
Registered User Joined: 12 April 2017 Location: USA Status: Offline Points: 59 |
Was there a noticiable difference in performance by adding the dog leg?
Mint Event Resources
