  New Posts New Posts RSS Feed - Start to finish pix. My MT122's!
stusparty View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote stusparty Quote  Post ReplyReply Direct Link To This Post Topic: Start to finish pix. My MT122's!
    Posted: 07 July 2008 at 12:56am
Taken a very long time, but worth every minute!
Loaded with PD123ER
Beyma CP750ti
TD400 flares
I'm running the PD123ER's with a Crown Xti 2000 (800watts @ 4 Ohms)
The Beyma's are running off a Crown Xti 1000
*PHOTOS HAVE VANISHED, WILL TRY AND FIND THEM AND ADD THEM BACK IN SOON!*
Needless to say they sound amazing! In our small basement club, you cant stand near them when you crank them up and they produce crystal clear sound. Really happy with the finish too, the paint is 4 thick coats of black Aldcroft.
Edited by stusparty - 25 September 2016 at 12:28am
4DPA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 4DPA Quote  Post ReplyReply Direct Link To This Post Posted: 07 July 2008 at 1:06am
tasty.......Clap
bs8901 compliant
Post Options Post Options   Thanks (0) Thanks(0)   Quote stusparty Quote  Post ReplyReply Direct Link To This Post Posted: 07 July 2008 at 1:47am
Thanks. Its my first build!
studio45 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote studio45 Quote  Post ReplyReply Direct Link To This Post Posted: 07 July 2008 at 2:25am
HOT DAMN they look great nice one :)
colinmono View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote colinmono Quote  Post ReplyReply Direct Link To This Post Posted: 07 July 2008 at 10:44am
Wow they look fantastic! What does the PCB connected to the HF driver do?
Tekasis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tekasis Quote  Post ReplyReply Direct Link To This Post Posted: 07 July 2008 at 11:54am
Sh*te! I can only see 2 pics from that lot!
**Heavy Weight-Line**
Drimacoustic View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Drimacoustic Quote  Post ReplyReply Direct Link To This Post Posted: 07 July 2008 at 12:01pm
IMO overload protection in case of crossover or amp failure - passive HP filter 2nd order.
oh, and nice build. Keep up.... :)
Edited by Drimacoustic - 07 July 2008 at 12:01pm
love begins below 40Hz
Post Options Post Options   Thanks (0) Thanks(0)   Quote stusparty Quote  Post ReplyReply Direct Link To This Post Posted: 07 July 2008 at 2:28pm
Its a high pass filter, mainly for added protection. Just incase someone plugs the wrong speaker lead in to the wrong plug at the back! LOL
Rockin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rockin Quote  Post ReplyReply Direct Link To This Post Posted: 07 July 2008 at 2:41pm
They look great mate, keep it up :)
breakdabeat pete View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote breakdabeat pete Quote  Post ReplyReply Direct Link To This Post Posted: 07 July 2008 at 5:13pm
well done
i tried to build a my122 but i decided to have separate top and mt flare boxes
bet they weigh a ton!
٩(̾●̮̮̃̾•̃̾)۶
Post Options Post Options   Thanks (0) Thanks(0)   Quote studio45 Quote  Post ReplyReply Direct Link To This Post Posted: 07 July 2008 at 5:45pm
mine have a lot more filler in than that :)
norty303 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote norty303 Quote  Post ReplyReply Direct Link To This Post Posted: 07 July 2008 at 6:37pm
Very nice indeed.
One mod i would suggest is to add a support for the compression driver so it's not taking all the weight on the horn.
A simple piece of wood that has a hole in it the same size as the comp driver should do the trick.  I've had a couple of breakages from fairly small knocks on cabs without braces
