Sticking/jumping turntable |
Frappy
New Member Joined: 20 January 2019 Location: Bedford Status: Offline Points: 3 |
Posted: 20 January 2019 at 8:59pm |
Having Googled various sites to help overcome the problem I had on one of my Stanton T 62 turntables, which was sticking at a certain point on either 33rpm or 45prm record, all I did albeit not the correct way, was to gently and very slightly undid the screw on top of the part holding the arm, and, for the time being it works. I can now play a record without it sticking/jumping.Give a shout if it works for you.
Guests
Guest |
Don't do this unless you really need to, as once you modify that screw you will need special equipment or the steadiest hand in the whole world to get it back to within the correct tolerances
bob4
Nah, bearing adjustment does require some care, but it is a very straightforward process. No need for "precision equipment". Just common sense really. You need a proper fine screwdriver. The tricky part is to get the tension just right. If it is too tight, the arm might get stuck. too loose, and the arm will have slack and vibrate in the bearing. You get to the sweetspot by trial and error. Just tighten and untighten, until it feels right and works well. |
Guests
Guest |
bob4
people claiming stuff on the internet, no source provided, not even a hint as to what they base their claim on. I consider that opinions, not facts. It is doable, I have done it on several 1210s successfully.
Frappy
Many thanks for all the replies to the action I took on my Stanton T62 turntable to prevent it sticking/jumping, etc.
Having been in radio for over 60 years playing records, even still doing today, I have picked up many an unorthodox trick or two with grams. The screw I undid was so minute that I hardly moved it, but it solved the problem! - the arm does not stick/jump having tried records that have scratches on them. Now I can start to play and record at home for a radio programme my extremely large collection of vinyl instead of playing CDs or mp3s from a laptop/desktop. I understand and accept comments about cost of resetting - but give it a try.
Guests
Guest |
Same like you're claiming? If you choose to do.it your anti skating will not work unless you are within the original tolerance. Technics fix for this? Full new tone arm assembly. It's fine if you want to do it, just make sure you know what you're doing!
