Strange interference |
Post Reply | Page <12 |
msoundsystem
Young Croc Joined: 10 November 2011 Location: wales Status: Offline Points: 625 |
Not yet. So a little update. I grounded the pe15 and the processor together via the earth screws at the back and it did nothing. I then tryed to use the ground lift switch on the processor but that did nothing.. i tryed to earth the pe15 via the screw into a plug via the earth on the same circuit as the processor and still did nothing, even tryed clipping the ground lead on pin one of xlr and it did nothing, if anything this was more noisey... Moving the pe15 away from the processor seems to cure it so i kinda guess its the power supplys interfering! Any more advice would be good as id like to have it sitting under my processor. Thanks!
simonp1100
Young Croc Joined: 01 September 2008 Location: Bristol Status: Offline Points: 1103 |
Have you ever thought the noise you are getting maybe down to digital noise inside your processor unit rather than the internal power supply ?, could be a possibility.
dj jammin
Young Croc Joined: 10 April 2010 Location: southampton Status: Offline Points: 770 |
OP says it happens when the 2 units are racked close together, so its an interaction between them presumably..
Msoundsystem.. can we have a bit more detail please? How are the units routed together? if you set up the lms and put the rane below it does the problem occur when the rane is powered up? Try like this with no audio connection between the units and report back if poss..
Reverence Sound system
BJtheDJ
Young Croc Joined: 28 November 2012 Location: Bristol Status: Offline Points: 884 |
Is there any change in the interference when their position in the rack order is changed ??
If your vaccinations were mandatory and nobody in your class had measles,
then you know that you're not a Millenial kid.</f |
Earplug
Ok, this is a weird one. Can you 'Bypass' the units? Try that - one at a time - and see what happens. That may give a clue as to where the problem lies. |
