"Strong motor and low qts equals less low end" |
Post Reply | Page 12> |
levyte357-
Posted: 16 May 2014 at 4:46pm |
Which suggests drivers like,
Void V18-1000, Prototype PD1852, Turbomax 1200, Are all rubbish on sub duty. Maybe someone here would like to comment on that. Edited by levyte357- - 16 May 2014 at 4:49pm |
toastyghost
I think you mean different - it all depends on your goal. For example the V18-1000 was really designed for cabinets that didn't do much below 40, with a big peak at 45. Strangely enough, when I've measured scoops or rear-loaded horns in the real world, that's where their peak is and where the sound man has gone 'feel that super low weight'…
Edited by toastyghost - 16 May 2014 at 6:40pm |
levyte357-
Granted, Scoops are better 40hz+ for the real SPL range, but I've lost count how many times Scoopists have been ridiculed or called nutters, for wanting amps that can do strong 40hz, or talking about 40hz HPF. Sure I've seen it posted on forum, number of times, 40hz is where many Pro PA firms cut their sub. Edited by levyte357- - 16 May 2014 at 6:58pm |
ceharden
The statement holds true to some extent in a reflex cabinet because the drivers are not well suited to that cab design. You can get plenty of sub out of those drivers in a cabinet with higher air loading such as horns and bandpass. A reflex cab just doesn't load the driver enough to make use of the motor strength.
Autograff
Young Croc Joined: 22 October 2008 Location: Sheffield , UK. Status: Offline Points: 1361 |
V18-1000 loaded supers have been measured in a block of 4 doing quite a meaty 33hz before. Edited by Autograff - 19 May 2014 at 3:17pm |
Liquid_Steel_Sessions
R8 Records |
levyte357-
Not possible, "Scoops can't do deep sub". Only 2x18s can go that deep [/sarcasm] |
ArthurG
Young Croc Joined: 03 May 2004 Location: France - China Status: Offline Points: 976 |
Thanks(1)
I love how with some people it's all white... or all black...
ask after that to have a smart and interesting discussion...
jammin75
Old Croc Joined: 08 July 2012 Location: west midlands Status: Offline Points: 2375 |
i have been told that scoops dont do sub !!!! |
JR.junior
Old Croc Joined: 14 December 2009 Location: Slovenija Status: Offline Points: 1789 |
MarjanM
4 scoops yes, might go low. My 21 inch rear loaded horn goes to 32hz as one box.
But one 18inhc scoop vs one double 18 dont have a chance.
ape3435
Young Croc Joined: 23 August 2009 Status: Offline Points: 552 |
Thought one hog did 35hz?
levyte357-
Marjan, would be great if you could bring 4x 218s to Golden Palace, London, to face 3x other decent Scoop systems, to test your theory.
Problem is, I'd guess you'd want more than the 32A, alloted to each system. |
