stupid question about tour labels |
Post Reply | Page 12> |
Mr Ed
Young Croc Joined: 03 October 2006 Location: United Kingdom Status: Offline Points: 581 |
Posted: 31 August 2019 at 7:04pm |
Ok how do i wipe writting off a tour label so i can re-label it
been written on with a sharpie tried foam cleaner, label remover and good old white spirit no luck at all sure im about to be shamed with a simple answer here -) thanks John
It's Nice to be Nice !
Alex_C
Registered User Joined: 13 April 2006 Location: Leeds Status: Offline Points: 180 |
Isopropyl alcohol
Danny A
Registered User Joined: 30 May 2009 Status: Offline Points: 444 |
odc04r
If IPA won;t shift it, then move on to Acetone. But be careful with it as it will likely damage the flight case surface and any other paint you get it on. Nail polish remover is acetone based.
Mr Ed
thanks Guys appreciate it
snowflake
oven cleaner if you have that handy
kevinmcdonough
Old Croc Joined: 27 June 2005 Location: Glasgow Status: Offline Points: 3749 |
PAL cleaner as linked above is the official one, but a squirt of WD40 also works great
James Tengo
Old Croc Joined: 09 May 2008 Location: Brighton Status: Offline Points: 2155 |
Drop of meths on a cloth also does the trick
AndyWave
Registered User Joined: 30 March 2008 Location: Finland Status: Offline Points: 380 |
Have you tried PRF label off, or other citrus based stuff? Many times removes permanent sharpie markings off plastics, depending how long ink has been applied. Label off needs good few minutes to be effective. Fresh citrus odour is a plus compared to tougher chemicals... Next would be the oven cleaner. Edited by AndyWave - 01 September 2019 at 2:59pm |
torturing electrons since ......
ceharden
As already mentioned, Isopropyl Alcohol (Isopropanol or IPA) is the best stuff to use. Evaporates without leaving any residue, won't affect most other materials. Also good for cleaning whiteboards etc in addition to removing flux residues from PCB's and many other uses.
Kr3 DSS
Registered User Joined: 02 April 2008 Location: United Kingdom Status: Offline Points: 156 |
Scribbling over with a dry wipe marker and wiping it off, a few goes of that and its gone. Works a treat when the idiots use the wrong pen on the darts score board in the pub
Kr3
Destiny Sound System.uk kr3dss@googlemail.com |
Digbethdave
Registered User Joined: 16 November 2018 Status: Offline Points: 406 |
Ipa. Don't use sharpies. Get some pentel markers.
