  New Posts New Posts RSS Feed - subs/ bass to pair with x15s
nuMOVEZ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote nuMOVEZ Quote  Post ReplyReply Direct Link To This Post Topic: subs/ bass to pair with x15s
    Posted: 17 October 2005 at 6:56am
Wondering what others have paired with the x15s to achieve a harmonious thump?!
I play a lot of jazz/ funk/ soul/ disco and US garage and house - there's a lot of acoustic sounds and live recorded production - i.e. not just drum machines and synths - certainly no "meth" house either.
ceharden View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ceharden Quote  Post ReplyReply Direct Link To This Post Posted: 17 October 2005 at 7:27am
If you're playing a wide range of music, reflex 18's are probably going to be the way to go.  Being direct radiating you don't need any time alignment with the X15's which simplifies things and you get probably the widest useable range compared with bandpass and horns.
Depending on how much bass you want, 1-2 18" boxes per X15 should do you right.
I don't have X15's but I run PS15's and similar tops with B&C loaded reflex 18"s with good results on everything from accoustic rock to house and D'n'B.
