  New Posts New Posts RSS Feed - Subs inside venues?!
dave23 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dave23 Quote  Post ReplyReply Direct Link To This Post Topic: Subs inside venues?!
    Posted: 21 June 2024 at 11:53pm
Best versatile front loaded horn sub for small to medium indoor venue events that will still blow your face off when used outside? Looking for 4 subs that can run fairly low but most importantly throw consistent bass pressure right in front of the stack without all bass just being outside the room and none at the stack. Any suggestions of any flh subs that work well inside even for low capacity events but also do what they do best still out in open.
There has been alot of suggestions with ported horns and tapped horns being the best for inside use but trying to find best solution for using a front loaded horn bass section that is a decent all rounder, preforming well inside a venue as well as outside and preferably that would work in a stack of 4.
Thanks for any suggestions.
Edited by dave23 - 22 June 2024 at 12:07am
Crashpc View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Crashpc Quote  Post ReplyReply Direct Link To This Post Posted: 05 August 2024 at 7:04pm
Unfortunately, these needs go against each other.  Tapped horns are faring quite well, not sow ith hybrids like SB18/Cubo I have tried.
