  New Posts New Posts RSS Feed - Subs to go with F218 mk2s?
Post Options Post Options   Thanks (0) Thanks(0)   Quote toastyghost Quote  Post ReplyReply Direct Link To This Post Posted: 12 January 2019 at 1:27pm
Originally posted by boots-hifi boots-hifi wrote:
Originally posted by dylan-penguinmedia dylan-penguinmedia wrote:
If you’re deploying a Funktion One system,then using a recommended configuration makes a lot of sense.
I’d be hunting for some infras... or just more F218’s.
This. Also if you deploy subs correctly rather than just piling them up you’d be surprised how low and how much you can achieve.
No size pile of F218 will gain more than say 4-5Hz extension over a single cabinet. You will however get forward directivity.
The trick with any sub is to EQ down the peak at the upper end of response if you want people to think it plays deeper.
re-production View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote re-production Quote  Post ReplyReply Direct Link To This Post Posted: 12 January 2019 at 2:12pm
The infra hits 30hz no problem, the -3db point is 24hz I think.
corell View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote corell Quote  Post ReplyReply Direct Link To This Post Posted: 12 January 2019 at 2:15pm
and you know this because.... ?
no offense to anybody, it is just against all i know about BP4 enclosures...
Here is a Sim of the F1 Infrabass Plan you can find online with a PD186/2:
Edited by corell - 12 January 2019 at 2:38pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote re-production Quote  Post ReplyReply Direct Link To This Post Posted: 12 January 2019 at 4:09pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote corell Quote  Post ReplyReply Direct Link To This Post Posted: 12 January 2019 at 4:33pm
well this is the least reliable source i can think of...
MattStolton View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MattStolton Quote  Post ReplyReply Direct Link To This Post Posted: 12 January 2019 at 4:49pm
Originally posted by above linked page above linked page wrote:
Frequency Response ± 3dB: 25Hz - 80Hz
Dark day for the world when you can't believe what you read on a manufacturer's website, and Lord Golden Ear's site at that!
/sarcasm.
RealitySound View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote RealitySound Quote  Post ReplyReply Direct Link To This Post Posted: 12 January 2019 at 4:53pm
Thanks all for your input. Think I'll take 3 of my 4 out and play them in anger and see what transpiresBig smile
Music played through it will more than likely be soca, dancehall, trap, and whatever else the kids are listening to nowadays. Pinch
Anyone heard an infrabass before? Or a stack of 3 f218's?
http://hornplans.free.fr/f1infrabass.html
https://www.funktion-one.com/products/f218-mk2/
https://www.funktion-one.com/products/infrabass-218/
Enough with the bass jokes, Just drop it.....
Post Options Post Options   Thanks (0) Thanks(0)   Quote corell Quote  Post ReplyReply Direct Link To This Post Posted: 12 January 2019 at 5:00pm
the above simulation is made from this exact plan. One could say, it is not an infra at all, but that is up to your own interpretation...
I have heard piles of F218 multiple times. Indoors (thinking Berghain) it is absolutely fine for techno, house etc.
Outdoors, and with very "demanding" music such as trap, it is not enough "sub", no matter how much you stack (eg. Fusion festival with 32 bins per stage). But as said, you would need one 2x21" BR per f218 if you would want to cover the octave from 25-50 with authority. 21NTLW5000 or 21DS115 would be nice...
Pasi View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pasi Quote  Post ReplyReply Direct Link To This Post Posted: 12 January 2019 at 6:20pm
Not even close.
Pasi View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pasi Quote  Post ReplyReply Direct Link To This Post Posted: 12 January 2019 at 6:21pm
I've heard infra bass many times now, but none of that comes from any FK1 box...
fatfreddiescat View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote fatfreddiescat Quote  Post ReplyReply Direct Link To This Post Posted: 12 January 2019 at 6:31pm
If you have enough F218 you can do sub, you just need enough of them, eq the upper response and use a Linkwitz type transform at the low cutoff to extend as low as your headroom allows, even using a 6dB per octave boost will give a f6 into the 20’s, unlike a reflex box they can be boosted below their f3.
Post Options Post Options   Thanks (0) Thanks(0)   Quote toastyghost Quote  Post ReplyReply Direct Link To This Post Posted: 12 January 2019 at 7:35pm
Is this based on data or your ears?
