  New Posts New Posts RSS Feed - Suitable drivers for Super Scooper 18
tb_mike View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tb_mike Quote  Post ReplyReply Direct Link To This Post Posted: 08 June 2005 at 12:05am
Originally posted by Timber_MG Timber_MG wrote:
It's all about the motor strength for bass horns (the other parameters are nice for HF extension or findign an optimum) but I wouldn't expect a kicker driver to hold it's motor strength linearily for too much excursion and mike will well know what happens when you model up a Motor strength <5 (using square root formula) in most bass horns.
True,the large signal character is interesting.Couldnt the underhung high excursion hold its crappily low BL for more excursion than a overhung 5mm xmax,25mm xmech prosound type.
Just use a notch filter at Fc
munky lee View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote munky lee Quote  Post ReplyReply Direct Link To This Post Posted: 10 August 2005 at 8:48am
im soon going to build 18" scoops, for the first time.
i have two omega pro eminence 18".
what happen if i put these eminence drivers in the 18" super scooper? because super scoopers are made for precision devives.
do you think its better to build scoops as plans in the eminence manual?
Post Options Post Options   Thanks (0) Thanks(0)   Quote munky lee Quote  Post ReplyReply Direct Link To This Post Posted: 12 August 2005 at 6:03am
 i repost....
please, what would be the difference if i put eminence omega pro 18" drivers instead of pd1850 in those 18" superscoopers?
thanx,
mat
mans1000 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mans1000 Quote  Post ReplyReply Direct Link To This Post Posted: 12 August 2005 at 8:43am
Built my scoops from Rog's plans,Omega Pro's sound good in pretty in them.
Post Options Post Options   Thanks (0) Thanks(0)   Quote mans1000 Quote  Post ReplyReply Direct Link To This Post Posted: 12 August 2005 at 8:44am
Just to add to the above.I have another scoop with a 600w Celestion driver in it,don't know model no. but that also sounds ok.
Tom Umney View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom Umney Quote  Post ReplyReply Direct Link To This Post Posted: 13 August 2005 at 4:58pm
Probably Celestion Frontline 18 perhaps??
Edited by ToXiC
Matthias View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Matthias Quote  Post ReplyReply Direct Link To This Post Posted: 18 August 2005 at 6:38am
what do u think about the fane colossos 18B 600 watts,
has a qts of 0,23, the xb has 0.38 and same watts.
i always hear, lower qts is always better in scoops...?
Insomnia View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Insomnia Quote  Post ReplyReply Direct Link To This Post Posted: 06 September 2005 at 5:15pm
fane 18xb's sound the business in scoops i havent heard the diff between them and the 18b - but i alwayz think if you know something works -why change it- i would stick with the 18xb's, they are ideal in scoops, i bought some scoops with 18xb's fitted i used them for 3 years without any problems-when i took them out of the scoop- they were dated 1995!! without any signs of any problems or reconing! i do highly recomend them-
