Super Bass Horn V.02 by Startec (Quad Acoustics-F) |
Page <1 4041424344 46> |
skankinmoe ![]() New Member ![]() Joined: 23 February 2020 Status: Offline Points: 9 |
I can feel with you sushi, building these beasts is way harder then it looks...
sushi ![]() Registered User ![]() Joined: 27 March 2012 Location: Milan Status: Offline Points: 85 |
![]() About the last question on the thread, i'm afraid i tested the N401s in theese cabs for too short time and too low volume to feel like having an opinion. However, i think a K6 amp would barely drive the mentioned rcf speakers over their rms power.. while a K20 would be blowing the cones out, if not kept under control.. i say: why not considering the K10?? I think it could be the best solution, with 2x6kw 2ohm (6 cabs).. it would drive them harder than the K6 but without reaching their limit, and not wasting that much energy you could not use from the K20. Edited by sushi - 07 March 2021 at 7:13pm |
FOO ![]() Young Croc ![]() ![]() Joined: 23 December 2018 Location: Denmark Status: Offline Points: 663 |
Are you serious??? Wasting energy just because the Amp might be way bigger than needed? Its All about headroom dude.. and control.. If one cant run a rig with double or tripple the needed power, without burning coils to a crisp, one simply shouldnt Touch pro audio gear
Right, i actually run my speakers with oversized amps several times. There are some details that can vary the amount of power a speaker can absorb though: How are limiters set? How long are they playing? Is the heat inside the chamber dissipated in some way? I'm pretty sure the musical program can make a difference too... to make it short, a 36 hours party with fast and bass-heavy tekno music, mostly played by non-professional artists, with a diy rig sometimes controlled by non-professional crews, could be really different in terms of performance and results than the average concert a pa tech is used to. I would not suggest a stranger to overpower his own gear without knowing any detail or his skills level.
VECTORDJ ![]() Registered User ![]() ![]() Joined: 11 June 2006 Location: United States Status: Offline Points: 478 |
Love this stuff about overpowering woofers....Call VECTORSONICS (Auburn, Maine USA) for recone work...Thanx, VECTORDJ
Underpowered, Vs equal Vs overpowered amps is a no-brainer.
Headroom is a absolute must! I am running LAB 12K44 on comps. Insane overkill, but i still havent seen a law that say "you shall always run flat-out" ![]() Its all about limiters. Simple as that. You need 1000watts? Get 2000
I get woofers (pre covid) that the coils are melted, the coil/cone joint broken, coils that welded into the magnet, coil wire off the coil former, etc......over and over again....I love it...woofer specs say 1000 watts...put 4000 to 5000 watts into it.......I Love it.....Keeps Me busy......Gas Money for My boat......Use more woofers not more power into a few.....6 to 8 subs a side at safe levels sounds better and lasts a lot longer then 1 woofer a side driven to insane power levels.......But I do not care because I need more gas Money and boat parts for this summer........send Me Your recone work....I Love it.
Let me repeat myself. Headroom.... Its All about headroom. 1000watt woofer with a 1000 watt Amp isnt a good combo. The Amp Will struggle to deliver. Always double or tripple the Amp power. Anybody stating otherwise shouldnt deal with audio gear.
subslut ![]() New Member ![]() ![]() Joined: 16 July 2021 Status: Offline Points: 1 |
hi Sushi,
them bins look sweet! you must be well happy with them!?.. im planning on making a couple myself but need to order the wood,. just wondering how many sheets of ply did you end up using to make a pair?
cheers! |
Hi! Thanks for props! I didn't heard them yet unfortunately, but owner tells they sound dope so i'm trusting him for now
![]() Iirc it took 11 or 12 sheets (250x125cm) to make 4. I made a cutlist on workshopbuddy.com, useful online tool i must say.. avoids a lot of tetris playing and wood waste. Just remember this cab's response take a significant dip around 50hz, which gets normally flatten when using 6 or + in a stack, so if you are going to build a pair you'll probably need to eq the bottom end a bit. |
HeteBliksem ![]() New Member ![]() ![]() Joined: 24 October 2021 Location: belgium Status: Offline Points: 2 |
hi everyone, i got 2 weeks of vacation coming up so i decided trying to build the SBH to keep myself a bit busy
![]() I'm a pretty handy so i'm not worrying too much about the construction of the cab itself, but its the first time ever building a speaker so i do have some questions. Forgive me if these are stupid or if there are already topics about my questions but like i said, i'm a completely new to this! First of all i was wondering about the cable that goes to the connectors. i suppose the connectors are placed under the removable part in the back, but to get there with the cable, do i have to drill a hole in the panel under the driver to pass the cable to the backpanel is that correct? and is there a specific place to drill or doesn’t it matter if its in the middle or on the sides? or do i have to follow the path of the horn until i get to the backpanel and not drill at all?? Second, i dont know anything about wiring speakers, connectors, etc... so is there a topic in here somewhere where i can read about this and where i can find some practical information/links or videos about what kind of wires i should use and how i have to wire the drivers and connectors? in general just information about the practical electrical part? Also, do i paint the entire speaker? inside and outside? or just the outer visible parts? and what kind of paint should i use? At last, if there are some sites, topics, videos that u recommend watching/reading, about cab building/ wiring speakers or anything else, please share! thank u very much guys! ![]() |
