  New Posts New Posts RSS Feed - Super Bass Horn V.02 by Startec (Quad Acoustics-F)
 Post Reply Post Reply Page  <1 444546
AcidDropper303 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AcidDropper303 Quote  Post ReplyReply Direct Link To This Post Posted: 26 April 2022 at 8:13am
Hey people!Cry I tried to find the Plan PDF from  http://www.pcorporation.net/SuperBassHornv2.pdf - SuperBassHornv2.pdf by Startec since the website is gone down. Please can any of you help out here? For the future I wanna build 4 of these as center and amp them with Powersoft K20+Limiter =) Feel free to Post it here to make it available to the Internet community again or mail me aciddropper303@gmail.com, thank you in advance - hope to get the Plan or meet someone who has got it for the future build <3 Otherwise I have to buy expansive F1 F124 much later instead, money money money - Maybe it will be just 4 WSX instead, tho I want the below 30hz Infra in a Horn up to 125hz :( F1 218 Infrahorn is most likely phasing a bit and also expansive as hell :D Much love from a learning professional, now starting with 6 Void V18-1000 in 2speakerplans X1, 2JBL4818 & 2 EV T18 parralel @MC²AudioE45 2ohm each channel =)LOL
levyte357- View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote levyte357- Quote  Post ReplyReply Direct Link To This Post Posted: 26 April 2022 at 8:55am
Originally posted by Toss Out Toss Out wrote:
i think i ll go with l18p300 and wsx...i saw specs comparing 18lw2600 and rcf and this is better..i was wrong with all
There are quite a few modern drivers, that would be better in WSX, than original RCFL18P300.
Would also suggest you go hear WSXs playing, in venues, of similar size, to those, you intend to play them in.
WSX are "NOT" best suited, to smaller venues.
Post Options Post Options   Thanks (0) Thanks(0)   Quote levyte357- Quote  Post ReplyReply Direct Link To This Post Posted: 26 April 2022 at 8:58am
Originally posted by citizensc citizensc wrote:
For anyone that owns or loves the SBH, maybe stop reading here... your feelings may be hurt
<SNIP>
I have been planning on designing a 18 inch and 21 inch FLH and posting it here but I have been very busy as of late. I am finishing my masters and moving 3500km to take a new job before the end of the year but I may find time when I settle down in the new year.
Have you ever seen the Modified Lab sub plans, for a 2x15" version?
Post Options Post Options   Thanks (1) Thanks(1)   Quote toastyghost Quote  Post ReplyReply Direct Link To This Post Posted: 26 April 2022 at 9:28am
The F124 is in a different league to the SBH. I’d save your money.
DMorison View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote DMorison Quote  Post ReplyReply Direct Link To This Post Posted: 26 April 2022 at 1:37pm
No comment on the quality of the design or any alternatives, but the Wayback Machine still has it: https://web.archive.org/web/20121119193411/http://www.pcorporation.net/SuperBassHornv2.pdf
HTH,
David.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AcidDropper303 Quote  Post ReplyReply Direct Link To This Post Posted: 26 April 2022 at 2:27pm
Thank you for the fast response, I will look into everything available again when it's time
JACKCO520 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JACKCO520 Quote  Post ReplyReply Direct Link To This Post Posted: 30 July 2022 at 12:49pm
dear
for de 21 inch sbh you have to go to speakerplans eu  thats allmost the same as the sbh for 18 inch
regrads
valle92 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote valle92 Quote  Post ReplyReply Direct Link To This Post Posted: 23 October 2022 at 7:39am
i had the opportunity to measure my 6 against 6 martin s218 in the same venue if someone cares..... , i was pleasantly surprised to not see the often discussed 50hz dip (could have been the room? but the 218 look worse....).  this is with all filters on (hpf bw24 / 26hz, lpf lr24 129hz)
Edited by valle92 - 23 October 2022 at 9:19am
Post Options Post Options   Thanks (0) Thanks(0)   Quote levyte357- Quote  Post ReplyReply Direct Link To This Post Posted: 03 May 2023 at 12:22pm
Any other feedback on these cabs, with hefty 5" VC 18" drivers, playing Reggae/Dub.
From plots and measurements I've seen, I guess they need plenty of shaping eq, (Dependant on driver).
Question is, do they do decent 45hz, in stack of 2x !?
As 186 horn will do this with modern drivers, no problem, and is smaller cab.
Edited by levyte357- - 03 May 2023 at 12:22pm
This page was generated in 5.594 seconds.
