Super Bass Horn V.02 by Startec (Quad Acoustics-F) |
Post Reply | Page <12345 46> |
dj-panoramix
Registered User Joined: 28 September 2005 Location: France Status: Offline Points: 462 |
biotec
Old Croc Joined: 07 June 2004 Location: United Kingdom Status: Offline Points: 2932 |
that's my friend Kev at frenchtek this year.
You can see the mattress he has in there, it damps the vibrations and its actually pretty comfortable. I would wear ear plugs or defenders but at some parties it's by far the most comfortable and safe place to sleep.
mykey
call me stupid, but where's the HF in that system above?
login4
Old Croc Joined: 03 April 2006 Location: Wales Status: Offline Points: 1552 |
it make me smile seeing people sleep in bass cabs, iv had a few peeps in my scoops at house parties over the years, nutters
ye i was also thinking that Mykey, unless its some sort of point source horn in the upper part of the horn, i hope these are the Mid/top plans we were promised by Panoramix.. |
CELTIC SUBSONIC SOUND SYSTEMS
dj-panoramix
yes but mr startec have now put this speaker in his brand (because he had put many time in it and was really happy with the results) and sell it allready make or as the porn horn you can buy it and make by yourself ,i think a pair is about 700/800 euro all finished ,i will put more info soon.
it's a HP PHL12" hornloaded , coaxial hornloaded 6.5"(phl)+1"(bms) with phase plug
here's a picture:
Edited by dj-panoramix - 27 October 2008 at 8:26pm |
Paulo Duto
Registered User Joined: 06 January 2005 Location: Brazil Status: Offline Points: 123 |
Hi
Take a look at what Startec wrote about that SBH:
"Startec" a écrit :
See also the builder resting after work:
][/URL]
Regards,
Paulo Duto
tomschute
Old Croc Joined: 15 May 2006 Location: Mid Wales Status: Offline Points: 1817 |
I need some more info on these tops - they seem to fill a much desired area in the market. I want some especially at that price! The terra horn is a beauty - from a construction point of view, and im sure its performance is matched - but i really hate those bar handles - routed or bars but not both, ruins the original top notch construction i recons (not that it matters). |
www.stableaudio.co.uk Speaker Building Services |
Paulo Duto
Paulo Duto
mykey
Note that I have a joker, a sort of fatal weapon somewhere in a drawer; 32OO watts, 112 dB 1/w/m 3O to 125 Hz to -6 dB (and this is not figures in the air )...... Simple A true house of 3 meters with the good HP! I have the plan (it would be necessary to remake it for more more more very more legible to be scanné) A modification is possible to receive a RCF N4O1, HP that compares itself the more, Original HP (but with 2-3 dB in less all time). Here this fine corrected sub for the RCFN184o1. As always at my place, this is rather simple to construct, although there let us are cuts to angles. I recommend the usage of birch of 18MM (reinforced by 12MM for the door it is important! !!) The expansion type is not current; the objective was to obtain a little infra of a single cash register from which the hyperbolical very marked finalisation in exit This house descends to 4O Hz, by 4 under the 3O Hz probably 25-28 Hz with the RCF seen the specs. (measures were done to the era, with the 18" designated PHL, unfortunately, these grades no longer are available) Edited by mykey - 28 October 2008 at 1:07am |
Xmax extreme
Registered User Joined: 23 May 2006 Location: Pilipinas Status: Offline Points: 308 |
The name of these bass horns speaks for itself... SUPERB BASS HORN...
A really Superb Design by Mr Startec.. hope we could have more of his great works specially His midtops.. Hi Myke, now I'm a bit confused on which of his two designs i would start to build.. the Hybrid Horn or these SBH. I will be using HDF cause Birch Ply is not available in our place, wish they could have here in our place , and these would be really bloody heavy for HDF material. Need to import those birch from China or maybe in your place which is not practical on my part... Edited by Xmax extreme - 28 October 2008 at 7:59am |
Maximum Excursion
Don't criticize your own competition, it looks like a publicity of your own commercial products. |
mykey
If your only going to build a few then go for the SBH, for shear SPL and controlled low end
if your going to build allot more then go for the hybrid
What ply do you have there, can you get 9ply? you must have a marine ply there?
HDF will weigh a tonne if you build that SBH
tweeter box
Old Croc Joined: 21 October 2007 Location: United Kingdom Status: Offline Points: 6784 |
Looking at the first post, King Earthquake comes to mind. |
