  New Posts New Posts RSS Feed - Super bass horn / v1000 clash on plan
bmx42 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bmx42 Quote  Post ReplyReply Direct Link To This Post Topic: Super bass horn / v1000 clash on plan
    Posted: 19 January 2018 at 10:43am
Hi all,
Justhe drawing out the dims of a void v1000 driver( rather crudely ) I notice there is a clash between the driver and internal panel.
Currently already have sbh loaded and v1000 that fit perfectly without alteration. Unsure if this is through original design modification pre cut or if the driver does in fact just drop straight in.
Just wandering if anyone has any experience with this particular design / driver combo and if the design had to be modified for the driver to fit properly?
Edited by bmx42 - 19 January 2018 at 10:44am
DMorison View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMorison Quote  Post ReplyReply Direct Link To This Post Posted: 19 January 2018 at 3:34pm
Maximum diameter and maximum depth on the V1000 do not occur at the same place,  or in other words the corner that you think may foul the cabinet isn't actually a corner, that's probably why it works in real life.
