SUPER SCOOP ALTERNATIVE |
Five &
Registered User Joined: 22 May 2008 Location: Caribbean Status: Offline Points: 142 |
Posted: 18 July 2017 at 3:28am |
Hi I'm Currently Using Super Scoops Loaded With 21” RCF LF21N451 In A 3 Way System Setup Crossover At 90hz They Sounds Great I Love Them Very Much But Wood Worm Has Taken Them Over So I Have To Rebuild Was Wondering If There’s A Smaller Enclosure I Can Build That Would Give Same Or Similar Performance As The Super Scoops Are A Pain To Move Around With. |
Let The Music Play
Crashpc
Registered User Joined: 26 February 2008 Location: Czech Republic Status: Offline Points: 465 |
Hey. I guess there is not much similar. Every enclosure type has its strenghts and weaknesses, and that´s why we build them all, dependin on ones needs.
I just got 21" in a bassreflex box, and it is unlike any 18" I´ve heard before. The bass is thick and sick. But it propably won´t hit that hard in the upper range. Only thing you can do is to find an inch smaller scoop :-D |
bob4
mini/midi scoops if you like the sound of the big scooper…..
Rhino scoop with PD1850 for example can go flat down to 40 Hz (I've measured it), and has a nice punch. "Some" builders are said to have even more potent mini designs. But then comes the perpetual question of how to get a DIY plan. Don't ask me, this is the scoop forum, no one is supposed to disclose anything y' know cloak and dagger business seen? |
Dub Specialist Sound
levyte357-
bob4
Edited by bob4 - 31 July 2017 at 4:11pm |
midas
Old Croc Joined: 27 October 2011 Location: Cumbria Status: Offline Points: 2117 |
Who’s design are those bud? |
Started out as the MS MK2 , but with own mods/tweaked internals,
over built a little, more bracing all double inside the horn path, rear double baffle id done this few years ago cheers J
midas
Nice and tidy looking boxes.
