Super Scooper delay |
teeth
Topic: Super Scooper delayPosted: 13 June 2024 at 2:31pm |
hi, after the horn length / delay for these. not actually been able to find an answer weirdly, so if we get a vaguely accurate one i will edit this post so it comes up for others searching. thanks.
JBK
Joined: 03 March 2016 Location: Besançon Status: Offline Points: 279 |
Posted: 13 June 2024 at 3:23pm |
From the plan : https://www.speakerplans.com/index.php?id=18superscooper "horn length 2.22m" Then using a calculator like this one https://www.brightonsoundsystem.co.uk/calculator/audio-delay.php 6.47 millseconds Or just do the math yourself, speed of sound is 343 m/s at 20°C. (source : wikipedia) so 2.22 / 343 = 0.0064723032 seconds ~= 6.47 milliseconds If you don't like proper units I'll let you do the math with the one of your choice ![]() Edited by JBK - 13 June 2024 at 3:25pm |
levyte357-
Joined: 27 July 2012 Location: UK, South East Status: Offline Points: 8517 |
Posted: 13 June 2024 at 6:01pm |
Decent LMS, will allow you to delay by cm.
I have always delayed everything above the Sccops, not the Scoops. |
Sinai Sound
Joined: 09 November 2009 Location: Sheffield Status: Offline Points: 635 |
Posted: 13 June 2024 at 6:02pm |
When I used to use my reflex 15" on top of my scoops, my delay ended up being about 6.5ms
Which just so happens to be about the horn length It will entirely depend on which cab sits on top of your scoops of course |
Norseman
Joined: 04 March 2013 Location: Torquay Status: Offline Points: 132 |
Posted: 14 June 2024 at 5:38am |
my es18bph are 2.8ms delayed to the scoops. both are horns of course.
paulus
Joined: 14 December 2005 Location: SOUTH BIRMINGHA Status: Online Points: 3237 |
Posted: 14 June 2024 at 10:10am |
as said above, as a rule of thumb i take most full scoops as 2.1m if I don't know , my reflex kicks were 6.2ms and my hds were 4.8ms as I remember , i do mine by ear with the sweep freq test method , but once done and you select bypass makes you realize without it was act missing quite a lot
Edited by paulus - 14 June 2024 at 10:12am |
TRENDSETTER SOUND SYSTEM
