  New Posts New Posts RSS Feed - SUPER SCOOPERS
SUPER SCOOPERS
rootswarrior View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rootswarrior Quote  Post ReplyReply Direct Link To This Post Topic: SUPER SCOOPERS
    Posted: 10 January 2008 at 10:38pm
GREETINGS TO ALL, I NEED SOME ADVICE ON THE SUPER SCOOPER PLANS, ARE THE PLANS TO TRUE MEASUREMENT, WHEN I CUT THE PLY DO I NEED TO LEAVE A INCH OR 2 OR GO BY THE MEASUREMENTS GIVEN AND CAN THE PLANS BE USED TO MAKE DOUBLE SCOOPS.Smile
DUBPLATE STYLE!!!
login4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote login4 Quote  Post ReplyReply Direct Link To This Post Posted: 10 January 2008 at 11:39pm
lol, the plans are exact, dont bother with doubles it would be a nightmare, good luck on the build...
CELTIC SUBSONIC SOUND SYSTEMS
Jhodas View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jhodas Quote  Post ReplyReply Direct Link To This Post Posted: 10 January 2008 at 11:56pm
as above. plans are precise (otherwise what would be the point?) and double scoops would be hell to move, not to mention the fact that two side by sade behave near as makes no difference anyway.
Disco Stu View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Disco Stu Quote  Post ReplyReply Direct Link To This Post Posted: 11 January 2008 at 2:49am
No you DEFINITELY dont want to go leaving an inch or two.
In fact you dont want to be leaving any gaps, bottom line if you can see light through a crack go back and fill the hole properly or start again
Even a 2mm gap will compromise performance SIGNIFICANTLY, this aint no bookshelf youre building.
Stu
Edited by Disco Stu - 11 January 2008 at 2:50am
All you need to know is:
My acts:
bort_83 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bort_83 Quote  Post ReplyReply Direct Link To This Post Posted: 11 January 2008 at 9:09am
Are you planning to build a double superscooper?????
it's about 120kg, definitly not easy to move! also is over 123cm large... you will have problems with doors, lift and van.
or it will stay in your garage for years covered of dust :(
