  New Posts New Posts RSS Feed - Super scoops settings advice
Adam_Iron_Horse View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Adam_Iron_Horse Quote  Post ReplyReply Direct Link To This Post Topic: Super scoops settings advice
    Posted: 28 December 2012 at 3:05pm
Hey guys for new years ever were doing a bit of a link up with a group of guys who have a pair of 18xb loaded super scoops and a pair of X15s
We have a pd.186 loaded G-sub and 2 x12s and pretty much was hoping someone will be able to help me with delay, crossover etc settings for our ultradrive.
The g-sub will be run on one channel of our matrix xt5000G and the super scoops will be run on the second channel. So going by matrix specs on their site thats 1800W to each side.
Planning on running the scoops from about 40Hz-90Hz (Will i get away with running lower than this or is this a safe bet?) then was planning on running the G-sub as Bass/Kick maybe with a bit of over lap so from 60Hz-150Hz then the tops up from that.
What do you guys think?
Music being played will be all sorts but think House/Garage/Dubstep/Electro/Fidget/Bassline/Drum and Bass/Hardtek/Gabber/Breakcore
Pretty much all genres of dance music apart from psytrance (our mates are doing another section and cover that)
Any other tips for running with the scoops would be appreciated
Cheers guys :)
JR.junior View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JR.junior Quote  Post ReplyReply Direct Link To This Post Posted: 28 December 2012 at 5:20pm
You have to run scoop much lower! 31Hz.. for d'n'b, jungle, dubstep.
Edited by JR.junior - 28 December 2012 at 5:22pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Adam_Iron_Horse Quote  Post ReplyReply Direct Link To This Post Posted: 30 December 2012 at 1:52am
Ye?
Thought that they wouldn't hit that low without groups of 4+?
Any idea on the delay time for the supers?
Post Options Post Options   Thanks (0) Thanks(0)   Quote JR.junior Quote  Post ReplyReply Direct Link To This Post Posted: 30 December 2012 at 11:00am
start at this point, you'll see, long jungle/d'n'b/dub/dubsteb bass lines go low. You can always go higher if you think, you need no low bass btw..
levyte357- View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote levyte357- Quote  Post ReplyReply Direct Link To This Post Posted: 30 December 2012 at 12:47pm
Fane XBs  don't have Xmax to spare, neither do they have high BL to keep control at high power input.
Be safe, and run scoops with 38Hz hpf, 18db/octave slope.
Will have plenty of warm sub, and take drivers home still working.
Delay Gsub by 2.22M, X15 by 2.22M.
Supers Throw Humongously far, so maybe lay them Horizontal, to restrict it.
Keep close eye on the Matrix, being watchful for clip light.
SBC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SBC Quote  Post ReplyReply Direct Link To This Post Posted: 30 December 2012 at 1:32pm
leave the x15 at home, and just use the x12 for sweeter top end
agree with above
F.T.S.S.
Goodvibetribe View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Goodvibetribe Quote  Post ReplyReply Direct Link To This Post Posted: 30 December 2012 at 1:47pm
Will you not have to reverse the phase of the Supers as well if your doing it this way?
Post Options Post Options   Thanks (0) Thanks(0)   Quote levyte357- Quote  Post ReplyReply Direct Link To This Post Posted: 30 December 2012 at 2:09pm
I've played with all sorts of kick bins above scoops, and delaying as above required no phase reversal, and no cancellations occurred.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Adam_Iron_Horse Quote  Post ReplyReply Direct Link To This Post Posted: 30 December 2012 at 6:59pm
Cheers for all the input will keep it safe I think and run the scoops from about 38hz... cheers for the advice only problem now is one channel of our matrix appears to have gone awol but hopefully have a solution
el chupacabra View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote el chupacabra Quote  Post ReplyReply Direct Link To This Post Posted: 01 January 2013 at 11:48pm
i was very impressed when mixing bands on dubconductors superscoops (everything else is reflex) that their choice of not delaying to the horn path but simply to the compression driver led to very coherent bass. with hogs i've found it always to be a crucial aspect but seemingly not so with supers? i cannot remember looking at the phase however.
hope your new years linkup went well.
