  New Posts New Posts RSS Feed - Support for HD215
Support for HD215
Heathrow_B_line View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Heathrow_B_line Quote  Post ReplyReply Direct Link To This Post Posted: 14 August 2013 at 11:41pm
imo once you need more spl then two of below stacks its time to change cab designs to something beefier
Edited by Heathrow_B_line - 14 August 2013 at 11:42pm
mini-mad View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mini-mad Quote  Post ReplyReply Direct Link To This Post Posted: 14 August 2013 at 11:44pm
... did ya glue that UV flood up there? lol
nice little stack! lovin those mid-tops.. REALLY LOVIN THEM!
janovic_x View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote janovic_x Quote  Post ReplyReply Direct Link To This Post Posted: 15 August 2013 at 10:09am
Wow, this is really an amazing forum!
Letterbox X1 is perfect!!!!!!!
Thank you!!! LOLLOLLOLLOL
I think i will build 2 or 3 Letterbox X1, so i can put 2 HD215 on top of one X1!
I really like the kick, but for some events its nice to have a little support!
Post Options Post Options   Thanks (0) Thanks(0)   Quote mini-mad Quote  Post ReplyReply Direct Link To This Post Posted: 15 August 2013 at 10:55am
just remember X1s have a rep. for eating drivers so dont go buying cheap ones!
i believe the v18 1000 work quite well in them. what amps do you have to drive them?
Post Options Post Options   Thanks (0) Thanks(0)   Quote janovic_x Quote  Post ReplyReply Direct Link To This Post Posted: 15 August 2013 at 12:45pm
yes i know! its really difficult to get the void drivers in germany, so i thought of a Rcf L18P300!
Amps are TSA2200, thomann amps, but they powered the HD215, i think i need another one for the X1 boxes!
Post Options Post Options   Thanks (0) Thanks(0)   Quote mini-mad Quote  Post ReplyReply Direct Link To This Post Posted: 15 August 2013 at 1:12pm
make sure they are man enuff before you go down this route. see if a few peeps on here find them ok... i'd be mighty pi55ed off if they tore the sh1t outta them on their 1st outing
Thiele/Small Parameters
Resonance frequency:33 Hz
DC resistance:5.0Ω
Mechanical factor:8.3
Electrical factor:0.34
Total factor:0.33BL
Factor:23.5 T · m
Effective Moving Mass:180 g
Equivalent Cas air load:226 liters
Effettive piston area:0.113 m²Max.
Linear excursion (mathematical):7.8 mm
Voice-coil inductance @ 1kHz:1.9 mH
Half-space efficiency:2.30%
Edited by mini-mad - 15 August 2013 at 1:15pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote janovic_x Quote  Post ReplyReply Direct Link To This Post Posted: 15 August 2013 at 1:26pm
a friend of mine got 4 X1 (normal plan) with RCF L18P300 and it is working, he powering them with 1kw each X1.
Post Options Post Options   Thanks (0) Thanks(0)   Quote mini-mad Quote  Post ReplyReply Direct Link To This Post Posted: 15 August 2013 at 1:36pm
job done
Post Options Post Options   Thanks (0) Thanks(0)   Quote janovic_x Quote  Post ReplyReply Direct Link To This Post Posted: 15 August 2013 at 2:40pm
Here for example some experience:
http://forum.speakerplans.com/l18p300-in-x1_topic32638.html
