  New Posts New Posts RSS Feed - T.amp Quadro 500
T.amp Quadro 500
kevin tyler View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote kevin tyler Quote  Post ReplyReply Direct Link To This Post Topic: T.amp Quadro 500
    Posted: 27 November 2019 at 12:52pm
Hi guys
With relation to the above amp
What power would it give in bridge mode and at what impedance.
It doesn’t mention it on the pdf.
Thanks
Kev
citizensc View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote citizensc Quote  Post ReplyReply Direct Link To This Post Posted: 27 November 2019 at 1:00pm
From the pdf of the manual
In general, assuming the amp is capable of being bridged, a 4ohm amp will only bridge in to an 8 ohm load. To calculate the power output of two channels 8 ohm bridged, just add the output of two channels at 4 ohm.
Post Options Post Options   Thanks (0) Thanks(0)   Quote kevin tyler Quote  Post ReplyReply Direct Link To This Post Posted: 27 November 2019 at 1:11pm
Thanks very much for explaining that.
Much appreciated.
Kev
