T nuts n boltz |
teeth
Young Croc Joined: 05 July 2021 Status: Offline Points: 561 |
Posted: 10 May 2022 at 7:18pm |
What T nuts n bolts? I'm gonna sort out my driver situation! I've got some fanes woodscrewed in to some HD15's... that's not right. So looking to make the jump and get some T nuts and bolts... I've got some 18's on the way that will need them too. Obviously all speakers are different, but what are you using? Anything you'd recommend? Avoid? Found these, M8 looks pretty big and 40mm quite deep!
snowflake
I prefer threaded inserts to tee nuts. Little bit of PVA in the hole before inserting make them quite strong enough to hold a speaker. either way M8 is overkill and you might struggle to get the bolts through the speaker chassis - M6 is fine.
Tinnitus Rex
Registered User Joined: 31 October 2020 Status: Offline Points: 274 |
Just to be controversial and only if the baffle is plywood , Why would it be wrong to "just" use screws? The way I see it (feel free to disagree) is Using T-nuts next to the edge of a baffle cutout is always problematic as the flange often protrudes over the cutout and securing them from not pushing out ( make the hole small enough to jam them in helps).T-nuts are good for some things but are only a traditional way of securing a speaker because it seems to be a more respectful way of treating an expensive component. Threaded inserts are very nice ,but no good next to a baffle cutout. Clamps are a very poor solution but do fascilitate moving the problem further away from the baffle cutout, Fane and others have made wide flanges on speakers that solve all these issues (JBL are terrible for this) There are so many "Hi-tech" fixings (with torx heads) available these days that I can only see advantages in using threads directly into plywood . they will also never rattle loose.
Edited by Tinnitus Rex - 11 May 2022 at 6:41pm |
"couldn't we just like... use headphones?"
toastyghost
Remove your wood screws a few times and see how well they go back in.
T-nuts or threaded inserts are used because you apply tension to the load from both sides, and the baffle gasket doesn’t get torn up by a screw thread mating directly to it. If they’re fitted properly - glue and/or small screws to prevent rotation - and the right type of stainless steel, then they should outlast the wood by a long margin. |
Tinnitus Rex
I get it,it seems the right thing to do , but we all take the speaker door off everytime we change the speaker and Ive never encountered inserts , t nuts or problems with those. I have used standard bolts directly into (decent) ply boxes to attach casters with no issues at all. I did a test years ago with a crow bar to try to pull them out and there's no way they are coming out without rotation.
Edited by Tinnitus Rex - 12 May 2022 at 12:27am |
toastyghost
Every speaker in our warehouse has inserts or t-nuts for the access panels. That was the case even in the early days, with a mishmash of DIY subs, Martin Philishaves and JBL bi-radial horns.
If you have access panels held on by wood screws, I feel sorry for you. It isn’t the case these days, but the first time I saw that on a Funktion One product with a list price of £5K+ I was genuinely shocked. It just gives the impression of not taking pride in the work. It probably doesn’t help that I was refurbishing them at the time, due to the wood screws corroding and the heads snapping off. I don't see any valid reasoning here other than laziness. The price difference in the fixings is pennies on a product that's going to retail for several hundred or thousands of pounds. The time difference is next to none of its planned as part of the build. |
jbl_man
Moderator Group Joined: 12 January 2005 Location: London. Status: Offline Points: 11154 |
The only down-side to using T nuts is when the threaded shaft of the nut works loose and spins endlessly, very annoying if you have no access to the rear of the nut to swap it out. (As happened to me on a couple of occasions).
toastyghost
I’ve had that once too. Invented a few new swear words that day 🙃
If you avoid the cheapest Chinese steel fixings and don’t use a drill on turbo torque to ram the bolts in, it should very very rarely happen though. The same way you try to avoid turning the head of a wood screw into jelly! Unless you mean the entire nut shredding the wood or falling out? That’s far less likely if you glue the buggers in, and put a couple of tiny screws to stop them rotating. A threaded insert is a lot easier to replace on an existing baffle than a t-nut, in my experience. Neither are particularly fun, but I know which I’d prefer. I'm surprised you don't see more threaded inserts used on the baffle in professionally built cabs. Edited by toastyghost - 12 May 2022 at 11:36am |
Tinnitus Rex
Obviously gold plated oxygen free T-nuts are better. In design for every problem you solve you create a new one (Dyson vacuum cleaners?) Above all ...Avoid modes of failure ,Less components, less to fail and utalise materials atributes . A list of my favourite speaker fitting problems in no particular order: The head of the fixing bolt is too big and clashes with the cast speaker chassis edge. The head of the fixing tears up the fabric of the edge support . The fixing needs to be overtightened to stop it working loose under use,we use lock washers and they do nothing.. The wadding of the box gets "involved" with the bolt threads and we cry. That last bolt we try to thread into the T-nut pushes the T-nut out and we cry. We are locked out of the box because the t-nuts are spinning. The allen bolt heads are trashed due to over tightning due to stopping them working loose. The angle that the t-nut spikes lock into the grain of the ply means they cant penetrate and bend flat . The T-nut hole was drilled too big and does not give a good friction fit. The start thread of the T-nut is damaged and will not start. The bolt was not greased when fitted and has rusted and jammed in the thread. The speaker mounting holes are mysteriously not a standard position! The gasket is so foamy it distorts the chassis when compressed. The (eminance) cardboard front gasket sticks to the baffle . The JBL mouting holes are too close to the baffle cutout. Some one thought it was "a thing" to make a slight rebate in the baffle around the driver cutout!!! Some speaker chassis wont fit "that" cutout . JBL speaker edge supports touch the baffle cutout and tear if back mounted. MDF baffles ?!? Please add to list.... Tis Blasphemy (and I dont often do it) but a Greased,pilot holed, countersunk torxhead screw would solve most of these problems and your not commited to any hole spacing. Edited by Tinnitus Rex - 12 May 2022 at 2:10pm |
csg
Shout at me if you want, but ever since owning my old Nexo SI system ( which used screws rather than t nuts and machine screws) i have used M6 screws, either pan or countersunk head as shown. Even with the heaviest drivers and the roughest treatment no loose or rusted in bolts, no issues whatsoever. I do use T nuts for wheels etc but for drivers, horn flares etc these every time.
Edited by csg - 13 May 2022 at 1:36pm |
JonB67
Ive always used fully threaded inserts. Not a fan of t nuts if you cant get to the back in the event of a failure.
I also dont see why, done properly and with the right fixing, screws straight into the ply wouldnt be perfectly sufficient. If it works, it works.
