Ta 2400 Help! |
BeAnTeK ![]() Registered User ![]() ![]() Joined: 31 October 2020 Status: Offline Points: 21 |
![]() ![]() ![]() ![]() ![]() Posted: 31 May 2022 at 1:34am |
Hi there just tryna figure out how to run my void v18 1000
On my ya 2400 in bridge mode am unsure what I need to switch and/or re-wire. Any help would be greatly appreciated. Many thanks
Also would running this amp in bridge mode be okay for this driver as at 8 ohm it chugs out 2300watts just don’t wanna cook anything.
BigSoundNorthWest ![]() Registered User ![]() ![]() Joined: 29 November 2014 Location: Manchester Status: Offline Points: 152 |
You'll need to switch it to bridge mode first,
Then, input into channel A. Output. Pin 1+ is 1+ (red post) on Ch A Pin 1- is 1 - (red post) on Ch B. |
Yes as long as you watch the input signal for getting too high, you should have miles of headroom for the driver.
