  New Posts New Posts RSS Feed - Ta 2400 Help!
Ta 2400 Help!
BeAnTeK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BeAnTeK Quote  Post ReplyReply Direct Link To This Post Topic: Ta 2400 Help!
    Posted: 31 May 2022 at 1:34am
Hi there just tryna figure out how to run my void v18 1000
On my ya 2400 in bridge mode am unsure what I need to switch and/or re-wire. Any help would be greatly appreciated.
Many thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote BeAnTeK Quote  Post ReplyReply Direct Link To This Post Posted: 31 May 2022 at 1:59am
Also would running this amp in bridge mode be okay for this driver as at 8 ohm it chugs out 2300watts just don’t wanna cook anything.
BigSoundNorthWest View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BigSoundNorthWest Quote  Post ReplyReply Direct Link To This Post Posted: 14 June 2022 at 7:56am
You'll need to switch it to bridge mode first,
Then, input into channel A.
Output. Pin 1+ is 1+ (red post) on Ch A
              Pin 1- is  1 - (red post) on Ch B.
Post Options Post Options   Thanks (0) Thanks(0)   Quote BigSoundNorthWest Quote  Post ReplyReply Direct Link To This Post Posted: 14 June 2022 at 7:58am
Yes as long as you watch the input signal for getting too high, you should have miles of headroom for the driver.
