  New Posts New Posts RSS Feed - tannoy t 12 an t300
tannoy t 12 an t300
7567kelsall View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 7567kelsall Quote  Post ReplyReply Direct Link To This Post Topic: tannoy t 12 an t300
    Posted: 12 March 2010 at 1:22pm
hi all can any 1 tell me the difference bettween the tannoy t 12 an t 300  passive speakers both dual concentric both the same rms both a 12 ,, driver i av a chance of buying either would like to know which are best for my application . solo artist so they av to be vocaly gud or i could get a pair of t i 8,, Confused
Nitz V1505 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nitz V1505 Quote  Post ReplyReply Direct Link To This Post Posted: 15 March 2010 at 2:42pm
I believe the t12 is a trapezoidal cab and the t300 a wedge stage monitor shape cab.
They do sound nice being a co-ax and all that point source mellarky and no one has done this style speaker for longer than tannoy.
Jasonstry View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jasonstry Quote  Post ReplyReply Direct Link To This Post Posted: 16 March 2010 at 9:43am
T12 is a wedge shape, I use 4 of them for monitors! They aren't the same power handling. The T12 is 200W/400W/800W and the T300 is 300W/600W/1200W. However the T300 is more sensitive than the T12, so goes quite a bit louder. It has a wider dispersion, 90 degrees compared to 60 degrees. The T300 is a bit bigger and heavier. I think thats it.
Andy
brokenjoe View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote brokenjoe Quote  Post ReplyReply Direct Link To This Post Posted: 16 March 2010 at 10:34am
really liked my t300s had 8 altogether, but not a brilliant throw on them..
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nitz V1505 Quote  Post ReplyReply Direct Link To This Post Posted: 16 March 2010 at 1:19pm
Andy
Your right mate, I got confused with the i12 .LOL
youthman1979@gmail.c View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote youthman1979@gmail.c Quote  Post ReplyReply Direct Link To This Post Posted: 09 November 2021 at 12:47am
You ever seen these before ? Tannoy T-300 with 2 15” subwoofers non concentric . Tannoy Canada with full range and  sub in inputs both XLR CONNECTION .  I’m not sure how to post pictures .
Edited by youthman1979@gmail.c - 09 November 2021 at 12:59am
DMorison View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMorison Quote  Post ReplyReply Direct Link To This Post Posted: 09 November 2021 at 1:48pm
I think you need at least 10 points (ie posts) to enable the option to upload directly to the forum - presumably that's to prevent spam. Once you have those points, you can upload by hitting the relevant button in the post editor. /this first button takes you to the Full editor:
Then this one lets you do the upload:
However, the forum software does compress images, so if you want high quality this isn't always the best option.
Otherwise, you can host on an external site like imgur which I've used for that example above and paste the bbcode for the images into your post to make the pics show up here.
Edited by DMorison - 09 November 2021 at 1:58pm
