Tannoy T12 |
Post Reply | Page 12> |
Earplug
Posted: 21 February 2018 at 4:46pm |
Anyone know what driver was used for this cab? I´ve tried the Tannoy website and they don´t even list the T12.
I have seen the number 3142 mentioned somewhere - is that correct? And who would stock them? I´m also after a diaphragm for this - anyone know where they could be found? |
markie
Old Croc Joined: 31 October 2005 Location: Sunny Liskeard. Status: Offline Points: 4570 |
Lockwood audio have diaphragms for most Tannoy duals. They will almost certainly know which driver it is and most likely have it in stock...... but don't expect it to be cheap.
http://www.lockwoodaudio.co.uk/tannoy.htm Edited by markie - 21 February 2018 at 10:54pm |
Earplug
Ok, thanks - I´ll drop them a line.
Some of the Tannoy stuff is stupidly priced. I found this: http://www.fullcompass.com/prod/090800-Tannoy-8001-0220 which looks similar (I don´t actually have the T12 cab here yet - just some photos). |
MattStolton
In my experience, mostly with Tannoy VXXi range, Fane paperwork and diaphragms. So you can get parts from any of the usual suspects that stock that stuff, or Fane themselves, pro-forma.
Jasonstry
Young Croc Joined: 11 September 2007 Location: Cannock. J11 M6 Status: Offline Points: 1367 |
I have a load of T12s and have made a habit of buying up boxes and part blown drivers on ebay. The I12s use the same drivers and I bought 4 for peanuts and made 2 good drivers. The boxes aren't much good outside of instals. There are some i12s listed atm but most are over-priced. You sometimes find recone kits/diaphragms listed as well but they aren't cheap.
Down with signatures!
Earplug
Ok, thanks - I´ll take a look at that. Lockwood had nothing. I took the opportunity to ask about spares for my Golds and even those where 'obsolete'. A bit worrying. |
MattStolton
The problem you may face, was the last time I spoke to Tannoy, was pre Music Group involvement. Good luck now.
However, Fane were helpful, and still have a UK contact details.
Earplug
Well, just received a mail from someone at Music Group asking for more details, eg. serial number, etc. And still waiting for the owner to drop off the cabinet. Mañana, mañana, guy...
cooky1257
Registered User Joined: 16 February 2011 Location: Wirral Status: Offline Points: 241 |
On another forum I posted I thought the HF on the PowerDual was a Celestion cd150-...I meant to say Fane CD150
Frank
MattStolton
I am sure it was something similar in the V15i I have been messing with over the last few years!
cooky1257
I see now the OP says its a T12 rather than the V12 cab so the driver in that uses a tulip waveguide and the 33mm HF dias are common across the CPA/I12/ DMT/some Prestige ranges for 12" and 15"s....7900 0199.
Same waveguide in the new Legacy range so perhaps they are holding back stock as they roll them out...
Edited by cooky1257 - 26 February 2018 at 12:56pm |
Earplug
Ok, just heard back from The Group and no diaphragm, but they can supply a whole new driver at quite a good price. Apparently the same as the VX12 driver:
"We no longer hold any more stock for the discontinued T12, but we have recently started to re-manufacture the VX12, which uses the same HF Driver as the T12. There may be some cosmetic differences though, but the sound and the fitting are a match. I've attached a service bulletin which will apply to the T12 regarding the HF Driver, but please note we currently only supply the whole Dual Concentric Driver (This is what I've quoted you)." |
