  New Posts New Posts RSS Feed - Tappedsymetrik 118
Tappedsymetrik 118
suiluj View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote suiluj Quote  Post ReplyReply Direct Link To This Post Topic: Tappedsymetrik 118
    Posted: 13 February 2018 at 4:35am
Working on a new project inspired from a tapped horn design but with symmetrical cone loading.
suggestions greatly appreciated. Smile
30Hz - 160 Hz  target freq
BooM BASSTIK EleCtronics and Communications Engineer
Live in harmony with one another. Do not be proud, but be willing to associate with people of low position. Do not be conceited.
Xoc1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Xoc1 Quote  Post ReplyReply Direct Link To This Post Posted: 13 February 2018 at 1:24pm
Most of the little reflectors will do nothing apart from making the volume smaller and the box heavier.
The angled baffles at the throat seem a bit large and look like they cause a restriction on the second 180 degree turns.
The cabinet will work a lot better if you add the back panel that's missing in the plan!
Have you plotted an unfolded horn path,  and done any sims with whatever drivers you prefer?
If so, post them.
Regards Xoc1
snowflake View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote snowflake Quote  Post ReplyReply Direct Link To This Post Posted: 13 February 2018 at 1:55pm
the divider in the middle is doing nothing (useful) acoustically
Edited by snowflake - 13 February 2018 at 1:56pm
Contour View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Contour Quote  Post ReplyReply Direct Link To This Post Posted: 13 February 2018 at 4:22pm
This idea already exists, search for cyclops tapped horn.
Post Options Post Options   Thanks (0) Thanks(0)   Quote suiluj Quote  Post ReplyReply Direct Link To This Post Posted: 14 February 2018 at 1:07am
If so, post them.
Xoc1,it's still a rough sketch and still needs some work to do. Yup there is a minimal restriction on that second 180 turn, I need to shorten the divider panel. The angled baffle is inline with the cut out diameter.
Cheers
Post Options Post Options   Thanks (0) Thanks(0)   Quote suiluj Quote  Post ReplyReply Direct Link To This Post Posted: 14 February 2018 at 1:12am
Yeah, yeah its more of the aesthetic part and to look symmetrically on the drawing
Post Options Post Options   Thanks (0) Thanks(0)   Quote suiluj Quote  Post ReplyReply Direct Link To This Post Posted: 14 February 2018 at 1:21am
Thumbs Up Seen and listened to the cyclops personally.
Hemisphere View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hemisphere Quote  Post ReplyReply Direct Link To This Post Posted: 14 February 2018 at 12:32pm
Looks sufficiently distinct from the CB-18 Cyclops to be interesting. Even if you fully optimise the design, the gains over the much easier to build Cyclops design will still be minimal, but I think gains are possible with this approach.
Phase 1: Post on Speakerplans
Phase 2: ?????
Phase 3: Profit!
