  New Posts New Posts RSS Feed - TCS2800
TCS2800
norty303 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote norty303 Quote  Post ReplyReply Direct Link To This Post Posted: 20 January 2006 at 8:14am
So can someone post this if they receive it from Ormenashe please.
If someone wants to send it to me, i'll put it up on my webspace and link for download
adam at subsonicsystems.co.uk
Jimbo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jimbo Quote  Post ReplyReply Direct Link To This Post Posted: 20 January 2006 at 1:42pm
I'll take it in Autocad.  I could screen print it for those that don't have access.
Jim
ormenashe View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ormenashe Quote  Post ReplyReply Direct Link To This Post Posted: 21 January 2006 at 1:10pm
So is it OK?
Did every body get the plans?
Does someone know how to calculate this type of cabinet?
What about the B&C 18pzb100 is it good?
If someone has more plans for this driver send me please?
Also links for brands companies that using B&C 18pzb100 in there
Products it will be fine.
Or
MixMan X View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MixMan X Quote  Post ReplyReply Direct Link To This Post Posted: 21 January 2006 at 1:12pm
I cant see how the plan make use of the rear chamber?
Mircea Bartic View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mircea Bartic Quote  Post ReplyReply Direct Link To This Post Posted: 21 January 2006 at 1:38pm
please, someone give me the plans too
office@*poweraudio.ro  please remove the *
Ex Nexus_3
Post Options Post Options   Thanks (0) Thanks(0)   Quote MixMan X Quote  Post ReplyReply Direct Link To This Post Posted: 21 January 2006 at 1:43pm
I've sent them to you. See if you can work it out.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mircea Bartic Quote  Post ReplyReply Direct Link To This Post Posted: 21 January 2006 at 1:46pm
thanks, got the plans
does not look to advanced, just a bassreflex in a "V" configuration, no horn at all in there. should have a bit of trow because of the mounting of the drivers, but nothing new under the sun really
Ex Nexus_3
Post Options Post Options   Thanks (0) Thanks(0)   Quote MixMan X Quote  Post ReplyReply Direct Link To This Post Posted: 21 January 2006 at 1:51pm
Yep, just looks like reflex cab, using a sort of loading with drivers angled towards each other. Do you think the chambers the drivers are in, and the rear chamber are all one big chamber?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mircea Bartic Quote  Post ReplyReply Direct Link To This Post Posted: 21 January 2006 at 2:09pm
yes, there must be an error in the drawing, there is one big chamber in there
I've seen this design used by a few manufacturers, and the only benefit is a reduced front surface for tight packing of large density subwoofer clusters
Ex Nexus_3
Post Options Post Options   Thanks (0) Thanks(0)   Quote MixMan X Quote  Post ReplyReply Direct Link To This Post Posted: 22 January 2006 at 4:23am
How can they claim -3dB @ 24Hz? seems very good for a reflex design, and it's not a huge enclosure.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mircea Bartic Quote  Post ReplyReply Direct Link To This Post Posted: 22 January 2006 at 4:53am
controller, maybe....?
Ex Nexus_3
doriitozkid View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote doriitozkid Quote  Post ReplyReply Direct Link To This Post Posted: 23 August 2016 at 10:25am
I know this page is 10 years old, but these clamshell designs of the TCS2800 is the final piece to an almost perfect 4 way system (if they truly do reach 25hz) which from experience these subwoofers really do outrun any F1 or Turbo box in its range!
Orikeiproductions@(g)mail.com <-- remove the brackets :)
