TCS2800 |
Page <123> |
norty303 ![]() Old Croc ![]() ![]() Joined: 18 August 2004 Location: Eastbourne Status: Offline Points: 8806 |
So can someone post this if they receive it from Ormenashe please. If someone wants to send it to me, i'll put it up on my webspace and link for download adam at subsonicsystems.co.uk |
Jimbo ![]() Registered User ![]() Joined: 07 March 2005 Location: United States Status: Offline Points: 420 |
I'll take it in Autocad. I could screen print it for those that don't have access. Jim |
ormenashe ![]() Registered User ![]() Joined: 10 July 2005 Location: Italy Status: Offline Points: 34 |
So is it OK? Did every body get the plans? Does someone know how to calculate this type of cabinet? What about the B&C 18pzb100 is it good? If someone has more plans for this driver send me please? Also links for brands companies that using B&C 18pzb100 in there Products it will be fine. Or
MixMan X ![]() Registered User ![]() Joined: 18 July 2005 Location: United Kingdom Status: Offline Points: 382 |
I cant see how the plan make use of the rear chamber?
Mircea Bartic ![]() Old Croc ![]() ![]() Joined: 18 February 2005 Location: Romania Status: Offline Points: 2581 |
please, someone give me the plans too
office@*poweraudio.ro please remove the * |
I've sent them to you. See if you can work it out.
thanks, got the plans
![]() does not look to advanced, just a bassreflex in a "V" configuration, no horn at all in there. should have a bit of trow because of the mounting of the drivers, but nothing new under the sun really |
Yep, just looks like reflex cab, using a sort of loading with drivers angled towards each other. Do you think the chambers the drivers are in, and the rear chamber are all one big chamber?
yes, there must be an error in the drawing, there is one big chamber in there
I've seen this design used by a few manufacturers, and the only benefit is a reduced front surface for tight packing of large density subwoofer clusters |
How can they claim -3dB @ 24Hz? seems very good for a reflex design, and it's not a huge enclosure.
controller, maybe....?
doriitozkid ![]() New Member ![]() ![]() Joined: 25 October 2014 Location: Australia Status: Offline Points: 5 |
I know this page is 10 years old, but these clamshell designs of the TCS2800 is the final piece to an almost perfect 4 way system (if they truly do reach 25hz) which from experience these subwoofers really do outrun any F1 or Turbo box in its range!
Orikeiproductions@(g)mail.com <-- remove the brackets :) |
Page <123> |
