  New Posts New Posts RSS Feed - Testing again
Testing again
Timo Beckman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Timo Beckman Quote  Post ReplyReply Direct Link To This Post Topic: Testing again
    Posted: 24 May 2018 at 7:22pm
Did another blog post:
I wanted to see the difference between the Powersoft X8dante and the Linea Research ASC48 both running a FIR file based on the same data and settings done via FIR Designer.
Had some problems with another brand (which shall remain nameless) so wanted to see if there was a difference.
The differences where minimal and most likely because of me tweaking on the Linea first which has small differences to the Powersoft X8 running just the FIR file.
The sound will be as good as the band play's
PremierMusicGroup View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote PremierMusicGroup Quote  Post ReplyReply Direct Link To This Post Posted: 04 October 2018 at 6:03am
Timo
I need a DSP to run FIR for Fulcrum Acoustic. Linea Research asc48 excellent like they claimed? How does it compare to Lake? Ashly? Powersoft X8 able to challenge XTA APA 4E8?
