TFL 760 Filter (eating tweeters) |
Futendra ![]() Registered User ![]() ![]() Joined: 28 April 2016 Location: Belgium Status: Offline Points: 276 |
![]() ![]() ![]() ![]() ![]() Posted: 21 September 2021 at 8:02am |
I suspect the filter in one of our TFL 760 is broken. The cabinet destroyed multiple tweeters, while other cabinets were doing fine with the same amp/ cable/ ...
I heard this is a common problem with the TFL 760, is there any more information about this? What exactly is breaking the tweeter? How would I go about removing the filter? If I understand correctly, the tweeters will be 8 ohm if the filter is removed, not 16 ohm? I recently found a post by Quentin Mrtk comparing the original CD-103 to a EV DH3 with the following measurements: Green: original turbosound Blue: Dh3 electrovoice ![]() This seems like a huge difference in response. I always thought the CD-103 is a rebadged DH3, but is this not true? Is it best to get the destroyed tweeters recoiled, instead of replacing them with DH3 diaphragms? Edited by Futendra - 21 September 2021 at 8:48am |
Conanski ![]() Old Croc ![]() ![]() Joined: 26 January 2006 Location: Canada Status: Offline Points: 2392 |
This thread may have some relevent info... Turbosound Floodlight internal protection filter - Speakerplans.com Forums - Page 1
A passive crossover or filter won't change a drivers impedance, but if it is damaged the driver can easily be blown. I suggest you take it out and inspect for damage, and then repair as necessary.
