Tham 12 cable and speakon socket position?? |
Jack1991
Registered User Joined: 05 February 2020 Location: Bristol Status: Offline Points: 495 |
Posted: 15 March 2020 at 10:04am |
Im midway through building my first Tham 12. And was wondering where people run the cable and where people position the speakon socket. I assume there is a specific way as to not affect the sound or that??
My thoughts were to drill a small hole just enough for the cable to fit through then seal it after. The speaker cable obviously the green line in the photo. (Nothing is glued yet so ignore the braces there just wedged in atm) Edited by Jack1991 - 15 March 2020 at 10:20am |
Joe Grime
Young Croc Joined: 28 February 2004 Location: E London Status: Offline Points: 850 |
Thats how mine are all routed to the speakon.
concept-10
Young Croc Joined: 17 May 2016 Status: Offline Points: 1293 |
In through the back as low as possible, secured to the bottom panel and bring it up through the baffle close to the driver.
Jack1991
Like this yeh? Out of interest does it make a difference what way it is routed i assume it would, but i cant really ssee why? Edited by Jack1991 - 15 March 2020 at 2:20pm |
concept-10
Yes exactly this, on our 12" tapped horns we have the cable going to the front so it is easy to connect to the driver, but you get the idea
APW
My 4 tham 12s have the routing as per your first diagram; just make sure you seal the hole....
Itโs a good idea to wrap the cable in self-adhesive cloth tape (Something like TESA 51608 loom tape is ideal) so the cables donโt vibrate or "Buzz" against the cabinet sides. Edited by APW - 15 March 2020 at 3:28pm |
Jack1991
Perfect thanks to all replies ๐๐๐ผ
