tham 15 and 18 used together: phase problems? |
Angelow
Registered User Joined: 17 March 2010 Location: italy Status: Offline Points: 199 |
Posted: 23 March 2019 at 12:59pm |
Having purchased 2 other res2 used and in anticipation of taking 2 more, I wanted to build 4 new cabinet tham shortly. currently I use a satellite on two or 3 "tham 15mo" (version with inclined panel to increase the mouth) com in figures 1 and 2, and since I have 4 faital 18hp1010 I would have thought of tham 18, but they can cohabit with tham 15 and above all Is it a good cone for that project? I should cut both the 15 and the 18 at the same frequency, I think 30-90 / 100hz is right. Another question, from the tham 18 I read that there is the old version and the new one, but what changes? Why do I use the tham instead of the pass-band slide sub? They are small and easily transportable and then the tham 15 used in a few units, compared to f118 in my opinion it has more hit on the pure bass. Obviously, if you put many f118 neighbors the situation changes, but it is not very scalable as a solution! thanks!
Edited by Angelow - 23 March 2019 at 1:01pm |
mstep77
Registered User Joined: 19 July 2006 Status: Offline Points: 457 |
What kind of music are you playing?
Angelow
in 90% of cases, electronic music, dance trance tekno
JonB67
You're running two different subs tham 15 and tham 18 in the same passband? Have i read that right?
Angelow
hi, i currently only have 6 tham 15mo, but since i have 4 unused 18 "woofers i would like to complete the system without buying new woofers 15, and i was wondering if i could have problems
Angelow
:) up :) up :) up
mstep77
You don't want to be running tham15 and than 18 in the same pass band. That is a recipe for disaster. If you want it louder sell the 18 and build more tham15. If you want it lower then try some double reflex cabs for the 18s and have a separate pass band for them . Maybe 35-65 on the 18 and 65-120 hz on the tham15. Just a rough guess for a start point.
toastyghost
Not always the case, you can get a TH115 and a TH118 to have matching slopes within 30 degrees from 50Hz - 100Hz with some delay and a PEQ point. They'll have some issues from mid-30s to 50Hz but nothing too dramatic, just no summation at the worst point where the natural rolloff of the smaller box comes into play. It's perfectly doable, with proper measurement and DSP approach. Which you'd need if you add an 18" reflex to the mix anyways, as well as having opposing group delay curves and a phase rotation to contend with where the port comes into play. |
Angelow
since I will use a different amplifier than the tham 15, I have a "ds 2.4" unused that I could use to filter the tham 18, as I could set it?
Jo bg
you need to measure them and get phase to match as close as possible, usually with allpass filters in dsp.
Xoc1
Registered User Joined: 15 October 2012 Location: Devon UK Status: Offline Points: 399 |
The TH115 and TH118 are both the same size and path. The TH118 being based on the TH115 with the bigger driver fitted on a modified baffle. The Tham 15 and 18 are different size designs and trying to get them to work well together might be more difficult.
Angelow
and if instead I use them in reflex? always with the same cut, I have to increase the bass, the kick the r2 have it already!
