THAM15 plans |
JOEDL1509
Joined: 22 August 2012 Location: South Africa Status: Offline Points: 28 |
Topic: THAM15 plansPosted: 02 October 2012 at 2:24pm |
Good day,
I am looking for the plans for a THAM15. Want to build a pair for my secondary setup that I use for small gig's just for low end fill. Further, if possible, please I be advised on the recommended driver to use in the THAM15 and alternative drivers, if available. I just don't want to invest too much as these units will be used infrequently. Thanking you in advance for all your assistance. kind regards Vishnu
bcs
Joined: 27 September 2010 Status: Offline Points: 216 |
Posted: 02 October 2012 at 2:43pm |
what do you have at the moment?
JohnnyPyro
Joined: 17 November 2008 Location: London Status: Offline Points: 2072 |
Posted: 02 October 2012 at 4:23pm |
Here you go fella
Lovely sounding cabs, i'm in the process of building 6
Powered by MC2 & XTA |
simonh
Joined: 07 November 2010 Location: Essex Status: Offline Points: 1772 |
Posted: 02 October 2012 at 4:54pm |
Considered owning a couple myself a number of times but always dropped the idea as I've never managed to hear any. Once you have built them, if you out and about using them, and wouldn't mind a fello sp member popping along for a listen, would be appreciated.....
JohnnyPyro
Posted: 02 October 2012 at 5:33pm |
Simon, mine wont be finished for a while yet .. i started them, then work went a tad mad
simonh
Posted: 02 October 2012 at 7:56pm |
Thanks mate, will do.
JOEDL1509
Posted: 03 October 2012 at 7:12am |
@ bcs -> for small gig's for about 60 people, I just use a pair of berry's B1520 pro's. For bigger gig's I have the B215XL's coupled with a pair of Cerwin Vega CVA121's. But Im in the process to upgrade the B215XL's to either HK Audio Premium Pro 10x or the RCF310's. So I was thinking for small gig's I can take a pair of THAM15's with the 10'' midtops. Visually for presentation at small venue's it will look much more professional & cuter than big a$$ 15'' cabinets sticking out. The THAM's I can tuck away in a corner or under the table
@JohnnyPyro -> thanks so much for the link, bud. If I can push my luck a little further, as I am not extremely good at reading plans. I can however put it together. Built a few good car audio boxes in the past....just those plans are kinda hectic. You wouldn't happen to have a cut sheet list of all the pannels. Would highly appreciate it. Oh & by the way, what is the recommended driver for this unit |
Roland
Joined: 06 December 2007 Location: Netherlands Status: Offline Points: 155 |
Posted: 19 October 2012 at 11:16am |
B&C TBX100
Tony Wilkes
Joined: 02 August 2004 Location: West Midlands Status: Offline Points: 4835 |
Posted: 19 October 2012 at 2:45pm |
B&C 15TBX100 or BMS 15S430v2* either will do you proud :)
Tony * 15N830v2 if you have a bad back or won the lottery |
rish
Joined: 18 June 2008 Location: Durban Status: Offline Points: 547 |
Posted: 19 October 2012 at 3:11pm |
With regard to your above comment that you dont want to invest too much on these units, the drivers for this cab will cost you a fortune. i think the b&c retails here in south africa for about R6000 and the bms is not available here. the efficiency of this cab is really based around the speaker you use otherwise if using a cheap speaker, you might as well build something else. i personally use these cabs for small functions and are great but with an expensive speaker off course.
Rish
lickweed
Joined: 02 May 2009 Location: leyton Status: Offline Points: 2525 |
Posted: 29 October 2012 at 10:56am |
Hi
Anyone knows would b&c 15nw100-4 work,I checked ts and they look simular with tbx. Nw100 has lower qes. Many thanks
http://www.liquidsound.co.uk/
