Author |
Topic Search Topic Options
levyte357
Posted: 12 February 2009 at 12:06pm |
RENSAAB
Posted: 13 February 2009 at 11:36am |
QUAD SERIES, 4 steps class H, On Semi Transistors
1800 @ 8 ohms
2700 @ 4 ohms
 E]
this is one powerful amp lev.... here are the rail voltages of this quad series.
± 50V
±103V
±157V
±200V
Damm!!!
With this sort of voltage swing, more efficient 16ohm drivers could soon be the way forward!
Ren
"The secret of the Scoop, what a wonderful piece of Science" - Tony ASS. "when the amplifier and voice coil are in complete synchronicity there is magic" - A Well Respected Amp Guru
levyte357
Posted: 13 February 2009 at 12:10pm |
1800 @ 8 ohms
2700 @ 4 ohms
± 50V
±103V
±157V
±200V
Damm!!!
Ren
Yeah, problem is, it will definitely be chinese, which means not cheap any more, and by the time you've got one, the company might have gone out of business.
RENSAAB
Posted: 13 February 2009 at 12:34pm |
levyte357 wrote:
1800 @ 8 ohms
2700 @ 4 ohms
± 50V
±103V
±157V
±200V
Damm!!!
Ren
I think you might be right
Old school high current 2ohm (or even 1ohm) stable amps get my vote right now
Ren
Xmax extreme
Posted: 13 February 2009 at 12:36pm |
Yeah, this is not an ordinary chinese amp, it's build with high quality components and uses genuine ON SEMI output transistors...  not cheap anymore...
Maximum Excursion
Don't criticize your own competition, it looks like a publicity of your own commercial products.
RENSAAB
Posted: 13 February 2009 at 2:07pm |
Xmax extreme wrote:
Yeah, this is not an ordinary chinese amp, it's build with high quality components and uses genuine ON SEMI output transistors... not cheap anymore... |
Feel like the threads been hijacked
Interesting amp! I'd like to find out a bit more about it. Are specs available for this beast?
mykey
Posted: 13 February 2009 at 2:36pm |
my amps from the Man called Arthur G
this is the 5k 12.2
the undressing virgin stylee pics
get the tissues out
can you smell that newness?
loving the power leads
Edited by mykey - 13 February 2009 at 2:57pm
Posted: 13 February 2009 at 2:57pm |
The cabling looks rather thick.
Have you tested it out yet?
Best Regards,
mykey
Posted: 13 February 2009 at 3:00pm |
yes already have a rack running for the last few months
a rack of .1's actually, will try the .2's tomorrow
just a tad over 5k i think, i'll check when i get in
Father-Francis
Posted: 13 February 2009 at 4:40pm |
this is the 5k 12.2
get the tissues out
You lucky B´´´d Big show off
Xmax extreme
Posted: 13 February 2009 at 4:42pm |
Interesting amp! I'd like to find out a bit more about it. Are specs available for this beast? |
Ok here is the basic specs..
8Ω Stereo Power = 1830W 4Ω Stereo Power = 3000W 8Ω Bridge Power = 5450W 4Ω Bridge Power = 8500W Frequency Response (+0/-0.3db 1W/8 ohm) 20Hz-20KHz(+0/-0.5dB) THD+N <0.025% S/N: 103 db Slew Rate 44V/μs DAMPING Factor : 900:1 Input sensitivity 0.775V,1V,1.4V Input impedance (bal/unbal.) 20KΩ/10KΩ Fuse: 25A Input voltage : 220V 50/60Hz Gross Weight 45 kg
Maximum Excursion
Xmax extreme
Posted: 13 February 2009 at 4:44pm |
I smell the newness myke  , nice one you have there
Maximum Excursion
