The beginning of Bliss Soundsystem |
Post Reply | Page <1 1112131415 17> |
Author | |||
Dub Specialist Sound
Classic case of drapes absorbing the bass
ie bit like to much wadding in speaker boxs imho dont belive all that drape bizzness tbh
been listening/playing heavy roots/reggae stacks for donkeys years, never no drapes thunderous bass/sub
BJtheDJ
Young Croc Joined: 28 November 2012 Location: Bristol Status: Offline Points: 884 |
That's marquees Bass goes straight through the canvas and the top bounces back at you Hey DJ!!! Turn up the Bass |
If your vaccinations were mandatory and nobody in your class had measles,
then you know that you're not a Millenial kid.</f |
SouthwestCNC
As cookie suggests. quite sensitive to it being correct or its like adding room adjustment. Can hear the bass sound like its being moved away from the bin. Top also gets a lot brighter when its out. |
SouthwestCNC
cookie-dj
They aren't. The top hats you drilled were too small, I tried to bore it out to fit, but the damage caused by
A) not having a pillar drill (or required steady hands) to drill a hole saw perfect central of the existing hole B) cutting holes in finished cabs is not smart anyway So I thought if I fit some external top hats fitted with insert nuts, it would be the best thing. |
You can't polish a turd!
SouthwestCNC
was it the diameter of pole that was too small for the weight of the midtop so larger top hat used? Yeah not an easy job to do and there's a cutout in the brace at 90 degrees to the hole and the same width so that would have needed widening too. Solution looks good tho and sturdier. It doesn't look as though it would have been possible to get that top hat in anyway, it looks too deep so would have hit a baffle. Edited by SouthwestCNC - 13 September 2017 at 3:11pm |
jammin75
Old Croc Joined: 08 July 2012 Location: west midlands Status: Offline Points: 2375 |
its all about the drapes the venue we used to do our nites in had drapes inside apparantly to keep the sound in nuff times had noise problems cuz of shaking up the car park , hotel upstairs the whole buildin all the windows in the houses on the next road i dont know wot the drapes were doin !! |
cookie-dj
Very sturdy indeed. I just foam gasketed the external pole mount to seal the hole and used some nice Allen bolts. The hole cut out was the same O.D as the 35mm speaker pole. I was going to buy some shallow internal top hats but I didn't like the fact they wobbled around quite a lot, it's the depth of the mount that keeps the pole nice and upright. |
cookie-dj
They had a Sentry SPL monitor in there, even though the bass wasn't as good as usual, I could still easily go into the red and risk having my power cut off! (Before anyone asks, there wasn't any more available sockets to bypass the sentry not that I would do that! ) |
jammin75
u can go rite in to the red i tripped one twice on a new years eve party !! i always bypass them if poss one of my subs runnin on a quarter of a tank used to trip one !! Edited by jammin75 - 13 September 2017 at 9:27pm |
cookie-dj
