  New Posts New Posts RSS Feed - The new ASS R2U system.
 Post Reply Post Reply Page  <1 1213141516 20>
levyte357 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote levyte357 Quote  Post ReplyReply Direct Link To This Post Posted: 10 March 2012 at 4:20am
As in most things, if not all things in Audio, it will come down to balance. You can get a flat response using a graphic on a scoop. once you've got it flat, it will be like a lot of other sub bass cabs.
My point exactly... Many, many Scoop owners know this...
Unfortunately in SP land, if it wasn't Tony who had said the above, it wouldn't be accepted, and probably ridiculed... Confused
Edited by levyte357 - 10 March 2012 at 4:21am
mykey- View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mykey- Quote  Post ReplyReply Direct Link To This Post Posted: 10 March 2012 at 7:25am
put a scoop side by side a proper PA bass cab. Test them 1 at a time then tell me why you would still want to use a scoop for PA
csg View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote csg Quote  Post ReplyReply Direct Link To This Post Posted: 10 March 2012 at 9:48am
My take on it is this
Not all scoops are equal - there are some ( RX JNR's with the B&C would be one example) i have heard that have a relatively flat response and a smooth sound that would make a very good general purpose sub for more or less anything
Other scoops i have heard i would class as more of an instrument - I.E. a speaker tuned to have a distinctive sound ( almost a growl) that suits its place in the roots / reggae scene.
Where all scoops fall down a bit is their upper end response - we all know about the phase induced dip, and depending on where this lies, this can make the box unsuitable as a 1 box bass solution. I know that Tony and others would never think of the scoop as a one box bass / sub unit, but that is what most "PA" companies want and expect - one box that can rumble and handle kicks.
So, i think it is about horses for courses - there are scoops around in the PA world, and there is no doubt that for dedicated sub use the scoop is a very effective solution - but it is not the only solution, and many of the other designs available are more versatile, making them more suitable for companies or operators that have to handle a wide range of program material and events, rather than having the luxury of being able to tune their rig to one particular genre.
Father-Francis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Father-Francis Quote  Post ReplyReply Direct Link To This Post Posted: 10 March 2012 at 10:40am
are we just say thing so we can have a discussion , cause 4 years now we dropped Br 218 and are using scoops for everything , eq is only on the monitors , we are still getting jobs and no complains , anyway people use what they think sounds best for them . for we scoops all the way .
TONY.A.S.S. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TONY.A.S.S. Quote  Post ReplyReply Direct Link To This Post Posted: 10 March 2012 at 10:58am
Mike, I always try to base what I say on experience. I have heard plenty of 2x15/2x18 subs from reputable manufactures and Hire companies, and what I have heard sometimes sounded like speakers waffling around in a big box. And the larger the system, the worse it got. I can cast my mind back to one of the last gigs I was at before the Rainbow closed. Boston was playing, and they were on of my favorite bands at the time. My disappointment came when listening to the low end which had no definition and seemed to be pumped up just to show how much bass they could get out of the system. Only at their loudest did the balance come anywhere near reasonable.
I saw the Eagles at Wembly, and most of that was a waste of time.
What I'm saying here is that just because the PA doesn't use scoops for subs, it doesn't guarantee that it will be any better.
Engineering will always be the key. I don't defend scoops as a manufacturer, because in the overall scheme of things, I have built far more normal Reflex cabs than anything else.
Post Options Post Options   Thanks (0) Thanks(0)   Quote levyte357 Quote  Post ReplyReply Direct Link To This Post Posted: 10 March 2012 at 12:05pm
Can let you into a secret, you probably weren't aware of.
If referring to scoops of correct design, and decent build, there is a point where the scoop is no longer controlling point of response, and it's then downto driver BL,  wadding, sound engineer's ability.
With correct wadding, I have heard 1850 scoop play from 35-120hz, with no nasty 50-75hz dip, or 80hz spike, all down to wadding and tuning with eq. Wink
Have heard scoop with Mid BL driver and no wadding play 45-100hz, flat musically, no eq, ust as HR predicted.
Post Options Post Options   Thanks (0) Thanks(0)   Quote mykey- Quote  Post ReplyReply Direct Link To This Post Posted: 11 March 2012 at 4:01am
Wasn't saying it was fact, was saying the best way is to try them side by side. This being the taller original scoop design. Mini's will be fine for PA
Also the trucking space for full scoops, it would be economical to use them
"I have heard plenty of 2x15/2x18 subs from reputable manufactures and Hire companies, and what I have heard sometimes sounded like speakers waffling around in a big box. And the larger the system, the worse it got"
yep, heard some 2 x 18 martin bins that sounded like that, and they were is a proper concert hall
bobbyg1441 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bobbyg1441 Quote  Post ReplyReply Direct Link To This Post Posted: 28 March 2012 at 6:58pm
Hi Tony , its Rob, I installed quite a bit of your gear for Barry  some years ago in London and Paris Hard Rocks, and a few other places I think, in fact I think we all went over to Paris together and hung some huge cabinets from the ceiling! Been reading about your new system with much interest, glad your still doing it, would love to hear the new system if poss? Hope you're well,
                regards Rob.
Motion54 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Motion54 Quote  Post ReplyReply Direct Link To This Post Posted: 28 March 2012 at 7:11pm
You can hear Tony's new system this Sunday in London
http://forum.speakerplans.com/soundsystem-soundoff-april-2012_topic64380.html
Post Options Post Options   Thanks (0) Thanks(0)   Quote TONY.A.S.S. Quote  Post ReplyReply Direct Link To This Post Posted: 28 March 2012 at 8:42pm
Hi Rob, welcome to the Forum. I remember the  Paris Hardrock install well, The big chains coming out of the ceiling and producing notes all on their own, until the buggers got Isolated. Anyway hope you have fun on here, don't take things too seriously and keep smiling. It can be quite entertaining.
Just remembered, there are some forthcoming gigs that I'm involved in at the Royal in Southend, One of which is called Bunker. (I think).
Edited by TONY.A.S.S. - 28 March 2012 at 8:44pm
kpb View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote kpb Quote  Post ReplyReply Direct Link To This Post Posted: 17 April 2012 at 7:28pm
growing.
Pahlavan-i View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pahlavan-i Quote  Post ReplyReply Direct Link To This Post Posted: 17 April 2012 at 7:33pm
Originally posted by kpb kpb wrote:
growing.
Now that is handsome!
Pahlavan sound =/= Sepas gozar-am
