  New Posts New Posts RSS Feed - The right basscab for dancemusic
DJ Maestro View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DJ Maestro Quote  Post ReplyReply Direct Link To This Post Topic: The right basscab for dancemusic
    Posted: 10 August 2013 at 3:28pm
Hi partypeeps,
Some guy told me last gig, scoops are not the best Basscab for the music I'm playing. I'm playing mostly Dancehall, Soca, House, merengue, Chutney songs from trinidad. For fast dancemusic like 140bpm and up the scoops are not the best cab..
my question is too all the music and basslovers here. is this true???if yes then what basscab are better then scoops for the music I'm playing?
grtz
mini-mad View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mini-mad Quote  Post ReplyReply Direct Link To This Post Posted: 10 August 2013 at 5:45pm
.. never run scoops myself, but i believe that they should be the best for what your doing.
but being dance music, as you say, try beefing up the upper bass section... the kick cabs, see if giving them a tweek gives a bit more "life" to your dance music
Post Options Post Options   Thanks (0) Thanks(0)   Quote DJ Maestro Quote  Post ReplyReply Direct Link To This Post Posted: 11 August 2013 at 1:11am
I'm running 4 miniscoops MK3 stipes with 2 SMT212..the discussion was about that a folded horn is far more better for dance music then scoops.  Those guys told me 4 folded horns is a better choice then my scoops.  I'm shocked and want some decent advise from the pro's.
grtz
Edited by DJ Maestro - 11 August 2013 at 2:18am
Sypa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sypa Quote  Post ReplyReply Direct Link To This Post Posted: 11 August 2013 at 3:58am
If you are not satisfied with your system and you find it too "slow" on bass or find the bass overwhelming, as mini-mad said build some kicks.
bee View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bee Quote  Post ReplyReply Direct Link To This Post Posted: 11 August 2013 at 9:41am
scoops were a common site in the late 80's and early 90's on the house scene. not so common any more, as people like smaller boxes. your scoops should be perfect for the musical choice, if you want to add a bigger punch in the kick (high bass) region add 15" kicks, if you want to add kicks (high bass) but less kicky ones with less punch look at some 18" kicks (high bass)
Post Options Post Options   Thanks (0) Thanks(0)   Quote mini-mad Quote  Post ReplyReply Direct Link To This Post Posted: 11 August 2013 at 11:16am
..see, the folded horns just give more kick to the music where the scoops just wont. they arent better then scoops they just reproduce a wider frequency band...  the answer is you need kick to your sound system and scoops wont do that. can you not hire/borrow some kick bins?
TONY.A.S.S. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TONY.A.S.S. Quote  Post ReplyReply Direct Link To This Post Posted: 11 August 2013 at 1:14pm
Definitely use both and make sure they're perfectly in time with each other.
levyte357- View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote levyte357- Quote  Post ReplyReply Direct Link To This Post Posted: 11 August 2013 at 1:44pm
As above,
+ Not all scoop/driver combos are made equal.
Some scoops+drivers are better than others.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DJ Maestro Quote  Post ReplyReply Direct Link To This Post Posted: 30 August 2013 at 12:02am
With other words, kick without scoops, is not recommended, correct me if I wrong.
and Horns I can use without kicks for the same freq use(scoops together kicks).
TENSiON View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote TENSiON Quote  Post ReplyReply Direct Link To This Post Posted: 30 August 2013 at 3:43am
"With other words, kick without scoops scoops without kicks, is not recommended for dance music"
There you go Tongue
Although it also depends on what you class as "dance music", but I would strongly recommend getting dedicated kicks (70-150Hz) for most kinds of that genre (techno,trance,hardcore,etc..).
I've seen some sounds on here who obviously use scoops without kicks and seem to be happy with it, but then again - those are probably not used with your usual "dance" material.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DJ Maestro Quote  Post ReplyReply Direct Link To This Post Posted: 30 August 2013 at 3:13pm
Originally posted by TENSiON TENSiON wrote:
[QUOTE=DJ Maestro]correct me if I wrong.
Hahahaha, yes I mean scoop without kicks...
Edited by DJ Maestro - 03 November 2013 at 5:37pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote DJ Maestro Quote  Post ReplyReply Direct Link To This Post Posted: 03 November 2013 at 5:48pm
And what about the Hybride bass cabs, like the MHB-46? bass and kick in one cab?
Anyone with experience with hybrides?
