  New Posts New Posts RSS Feed - THE T.AMP D3400
THE T.AMP D3400
Rockin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rockin Quote  Post ReplyReply Direct Link To This Post Topic: THE T.AMP D3400
    Posted: 04 June 2007 at 12:34am
THE T.AMP D3400
Just found these on the Thomann site.  They seem to boast quite an impressive spec for little money.  Usually when things seem too much of a good deal, they usually are. Am i missing something?
Anybody with any experience with thes amps?
http://www.thomann.de/gb/the_tamp_d3400.htm
Tekasis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tekasis Quote  Post ReplyReply Direct Link To This Post Posted: 04 June 2007 at 9:19am
You'll find some info over on here Rockin: http://www.speakerplans.com/forum/forum_posts.asp?TID=9298&PN=1
that login4 started a little while back.
I knew this amp had popped up before, so searched for D3400 & it popped up. You get me !!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rockin Quote  Post ReplyReply Direct Link To This Post Posted: 04 June 2007 at 2:33pm
Thanks alot Tek.
Found the amp on their site last night and was blinded by the figures which disengaged by brain.
/note to self.....Must check out this thing they call "search"
JD01 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JD01 Quote  Post ReplyReply Direct Link To This Post Posted: 05 June 2007 at 8:59pm
I think it's not THAT cheap. And how good they are at 2 ohms is still in question....
login4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote login4 Quote  Post ReplyReply Direct Link To This Post Posted: 06 June 2007 at 12:10am
i think im going to get one soon just too try it out, if it ant no good ill let peeps know and stick it on ebay....
CELTIC SUBSONIC SOUND SYSTEMS
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rockin Quote  Post ReplyReply Direct Link To This Post Posted: 06 June 2007 at 6:33am
Excellent idea
