  New Posts New Posts RSS Feed - THE T.AMP PROLINE 3000
 Post Reply Post Reply Page  <1234 5>
Nick Sasquash View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nick Sasquash Quote  Post ReplyReply Direct Link To This Post Posted: 15 May 2011 at 12:49pm
Yes tek, better protection on more expensive amps...... When I 1st got them i gave one a good test & ran it hard into clip & it shut down.... I powered down waited about 30 seconds, it powered back up & all was good, I have had the clip lite ficker on heavy dances & just backed off a little to just under clip as i cant afford to toast drivers as some have with proline 3000.
http://www.operationsoundsystem.co.uk
http://www.stores.ebay.co.uk/operationsoundsystemrecords
http://www.facebook.com/OperationSoundSystem
http://www.myspace.com/operationsoundsystem
Tekasis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tekasis Quote  Post ReplyReply Direct Link To This Post Posted: 15 May 2011 at 12:59pm
Cheers for that Nick! Will pass this info onto my mate who loves them!
If that happened when you ran it hard, seems to me the protection works quite good & is effective!
(Not advising to do it, just to know it works sometimes.)
Many other amps would have carried on working but with silence out the cabs & maybe a burning smell!
**Heavy Weight-Line**
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nick Sasquash Quote  Post ReplyReply Direct Link To This Post Posted: 15 May 2011 at 1:29pm
Yes Tek... the protection circuitry does work, jus a bit basic & not too forgiving if mistakes happen.
I have driven x3 Fane XB per side on one occasion when i had no other option, it did ok, - for a couple of hundred £s's extra tho..... give me a 2nd hand crown 5000vz everytime.
liboyi View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote liboyi Quote  Post ReplyReply Direct Link To This Post Posted: 14 August 2014 at 1:38pm
Hi I-sound,can we talk about this proline 3000 power amplifier ?can you manage to get spares?
wybinman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wybinman Quote  Post ReplyReply Direct Link To This Post Posted: 16 August 2014 at 11:20am
do people with void v18's & prolines prefer running
1 voids a channel (8ohm)
or
2 voids on bridge (2ohm)
Edited by wybinman - 16 August 2014 at 12:10pm
corell View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote corell Quote  Post ReplyReply Direct Link To This Post Posted: 16 August 2014 at 11:44am
one per channel will give you 1300 w rms into each speaker which surely is enough and sound and protection wise 8 ohm stereo shoulb be a lot better aswell.
Edited by corell - 16 August 2014 at 12:41pm
AM55 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AM55 Quote  Post ReplyReply Direct Link To This Post Posted: 16 August 2014 at 11:44am
2 Voids a channel, 4r. Everyone will strongly advise against running 2r bridge.
RUS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote RUS Quote  Post ReplyReply Direct Link To This Post Posted: 16 August 2014 at 12:08pm
as far as im aware there is no diffrence running an amp 4 ohm stereo or 2 ohm bridge.
Post Options Post Options   Thanks (0) Thanks(0)   Quote wybinman Quote  Post ReplyReply Direct Link To This Post Posted: 16 August 2014 at 12:11pm
sorry. i meant one void a channel or 2 on bridge
1100w (8ohm)
3000w (bridge)
Post Options Post Options   Thanks (0) Thanks(0)   Quote wybinman Quote  Post ReplyReply Direct Link To This Post Posted: 16 August 2014 at 12:12pm
1100w (8ohm)
3000w (bridge)
(tried 2 void a side in the past and it clips way too early)
Edited by wybinman - 16 August 2014 at 12:13pm
AM55 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AM55 Quote  Post ReplyReply Direct Link To This Post Posted: 16 August 2014 at 12:31pm
Other way round, 2r stereo is 4r bridge. 2r bridge would be 1r stereo.
1100w (8ohm)
3000w (bridge)
It's a budget amp maybe you are expecting too much form it. It you have the amp and cabs try each set up and see for yourself.
RUS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote RUS Quote  Post ReplyReply Direct Link To This Post Posted: 16 August 2014 at 1:18pm
sorry yes i knew that, i should read what i wrote twice and post once.
