  New Posts New Posts RSS Feed - The ultimate enclosure for the box 18-500 8a
bass*en*mass View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bass*en*mass Quote  Post ReplyReply Direct Link To This Post Posted: 10 November 2015 at 2:22pm
app what exactly are you looking for?
more spl or more sub?
reduced distortion and reggea  dont mix up in my books.. :)
app View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote app Quote  Post ReplyReply Direct Link To This Post Posted: 10 November 2015 at 2:48pm
Im not quite sure yetBig smile
"the ultimate enclosure" something which has it all with the driver mentioned.LOL
The reflex I use now sounds smooth and goes low but is not as loud as could be. Horn would be louder but wouldnt go as low. PPSL and bandpass boxes are something I dont know much about (yet).
But Id like to have it all, efficient,loud and low and something which could be used without separate kickbins.
Or a really good compromise LOL
Well see what our brains will possibly come up withBig smile
"what!?"
app View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote app Quote  Post ReplyReply Direct Link To This Post Posted: 10 November 2015 at 3:00pm
Originally posted by app app wrote:
Ive also been checking this http://hornplans.free.fr/mtl-46.pdf
Its quite efficient but dont go that low in singles/pair.
Ive just seen a youtube video about this enclosure loaded with the box 18-500. The recommended driver is different.
What I "like" about this design is the fact that I could build it since the design is quite simple. Its size is also good. If it only would go to about 40hz in singles...Looks like it would work without a kickbin too.
"what!?"
bob4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bob4 Quote  Post ReplyReply Direct Link To This Post Posted: 10 November 2015 at 3:08pm
for louder, you will need a beefier driver I'm afraid - or simply more of the same units. So in a way, PPSL helps a little bit, but you have double the cost for drivers.
Once you consider the amount of cabinets you need with a "wimpier" transducer to get even SPL wise with a single box loaded with a more powerful driver, the price difference might shrink... if you factor in the cost of wood, probably even more. And you'd have less boxes to carry for same output....
Anyway, would be an interesting exercise to compare two single 18" vs 18" PPSL output and sizewise.
I have a hunch it might do that
that's definitely a caveat
app View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote app Quote  Post ReplyReply Direct Link To This Post Posted: 10 November 2015 at 4:07pm
Thats true! Wouldnt mind having two ppsl boxes which take about the same space as two single 18" BR.
Edited by app - 10 November 2015 at 4:08pm
"what!?"
app View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote app Quote  Post ReplyReply Direct Link To This Post Posted: 10 November 2015 at 5:39pm
I simmed a 6th order bandpass.
Can take about 800W before going out of xmax.
129db at 1000w,xmax just a little bit over.
99db@1W
Rear chamber is 170l tuned to 38hz and front chamber is 76l tuned to 85hz.
Port air velocity under 18m/s with 1000w and group delay peaking at 27ms @ 25hz...
Ideas how to get the bottom to go to about 40hz and maybe a bit higher too in the other end?
This is the first 6th order bp Ive simmed ever. Does it look shitty?
Thanks!
"what!?"
app View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote app Quote  Post ReplyReply Direct Link To This Post Posted: 10 November 2015 at 5:50pm
Infact compared to the jbsub118 theres only 2db difference in theoretical spl and the jbsub118 goes deeper AND higherLOL
"what!?"
app View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote app Quote  Post ReplyReply Direct Link To This Post Posted: 12 November 2015 at 11:41pm
Please link 18" ppsl plans here if you have them.
Would like to see some plans to get a better understanding of the ppsl designs.
At the moment Im really interested in building a 18" ppsl enclosure for the box 18-500 8a drivers.
I wonder when people who have heard a ppsl sub say that the bass is different,different in what way? Less distortion yes but does it still shake the room and feel heavy or does it feel like something is lacking in the bass? Some say its the best sounding sub...
"what!?"
app View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote app Quote  Post ReplyReply Direct Link To This Post Posted: 13 November 2015 at 12:23am
I start to believe that these plans here are about as good as it gets for this driver... http://www.lautsprecherforum.eu/viewtopic.php?t=4561
"what!?"
_djk_ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote _djk_ Quote  Post ReplyReply Direct Link To This Post Posted: 13 November 2015 at 7:21am
The Qts is high enough on those woofers that the box will be a bit large.
I generally try and use drivers with a Qts around 0.312, this gives the smallest box, most efficient, and deepest bass.
djk
app View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote app Quote  Post ReplyReply Direct Link To This Post Posted: 13 November 2015 at 1:48pm
Yeah I read that you suggest building the enclosure 4 x the Vas of the drivers...That would make the enclosure really big.
"what!?"
Post Options Post Options   Thanks (0) Thanks(0)   Quote _djk_ Quote  Post ReplyReply Direct Link To This Post Posted: 13 November 2015 at 10:02pm
"Yeah I read that you suggest building the enclosure 4 x the Vas of the drivers"
That's not correct.
For a Qts=0.312 it is Qts^2 * Vas * 4.1
If the Qts is .3 vs .4 the cabinet will end up being about twice the size for the driver with the weaker motor (higher Qts).
djk
