The ultimate enclosure for the box 18-500 8a |
Page <123 |
| Author | ||
app
Joined: 26 December 2013 Location: Finland Status: Offline Points: 2435 |
Posted: 14 November 2015 at 2:35am |
So if the qts of the box 18-500 8a is 0.425 and Vas 208l the calculation looks like this: 0.425^2 x 208 x 4.1 = 154 approx So the enclosure size should be twice that 308l ? |
"what!?"
_djk_
Joined: 23 November 2004 Location: United States Status: Offline Points: 5992 |
Posted: 14 November 2015 at 6:26am |
The constant for a Qts=0.425 is more like 6 (rather than 4.1), so
.425^2 * 208 * 6 = 225L (per driver). I would need to get out the LDC to check the exact value for the constant for that Qts, but I think 6 will be close. It may be possible to do a C6 alignment (like my B6 PPSL designs), with a small amount of ripple in the response. I will have to check that on a different computer at home (posting from work at the moment). |
djk
_djk_
Posted: 16 November 2015 at 7:04am |
I ran some designs on this driver.
BB v6.0 suggested about 14.5 cu ft for a pair, and could be made to be 3dB down around 42.5hz. An alternate design would be a C6 of 8 cu ft net tuned to 40hz with a Q=2 filter at 40hz. This would be 3dB down at 40hz. Two ports of about 50 sq in each by 12.5" long will be enough. A pair of these drivers will handle about 2KW before getting into excursion problems with this design. |
djk
mini-mad
Joined: 13 July 2012 Location: london Status: Offline Points: 6861 |
Posted: 16 November 2015 at 7:23am |
i wouldnt mond seeing the plan for that DJK.... iv always wanted a double 18" reflex and it sounds like you may have come up with a nice "little" box there. If you wouldnt mind sharing of course. |
app
Posted: 16 November 2015 at 8:34am |
Id like to see the plans too if possible! PM me if you want! ![]() |
"what!?"
cravings
Joined: 30 January 2007 Location: Ireland Status: Offline Points: 7507 |
Posted: 16 November 2015 at 10:34am |
he's given you the info to start working on a plan..
bob4
Joined: 29 February 2004 Location: Finland/Germany Status: Offline Points: 1924 |
Posted: 16 November 2015 at 3:43pm |
thank you for your hints, and pardon my ignorance: what is C6 ?(I gather it's a specific alignment?) Can you point me to a good source of information? best regards, Bob |
_djk_
Posted: 16 November 2015 at 11:00pm |
" Can you point me to a good source of information?"
The LDC by Dickason Loudspeaker Design Cookbook 7th Edition Book
djk
AndyWave
Joined: 30 March 2008 Location: Finland Status: Offline Points: 381 |
Posted: 17 November 2015 at 6:14pm |
quote
thank you for your hints, and pardon my ignorance: what is C6 ?(I gather it's a specific alignment?) Can you point me to a good source of information? best regards, Bob quote end Hi Bob It is electrically corrected reflex alignment. So generally in smaller enclosure one can have same low freq output with aid of eq (and low cut filtering to keep Xmax in control below box tuning). one way of executing this By Mr Don Keele http://www.xlrtechs.com/dbkeele.com/PDF/Keele%20%281975-07%20AES%20Published%29%20-%20New%20Set%20of%20VB%20Alignments.pdf |
torturing electrons since ......
bob4
Posted: 17 November 2015 at 10:04pm |
much obliged! ![]() |
app
Posted: 17 November 2015 at 10:37pm |
Thanks for the link! ![]() |
"what!?"
_djk_
Posted: 18 November 2015 at 2:38am |
Don worked for EV, Klipsch, and JBL, he knows his stuff.
A PPSL cabinet for these would be about 24"H x 36"W x 30"D, with a plenum opening of about 9"W, and a shelf port on each side of the box about 2.375W X 12.5"D (I will see if I can make the ports bigger, this is the minimum suggested size). Edited by _djk_ - 18 November 2015 at 4:21am |
djk
Page <123 |
