Them fangled column PA S again. |
Post Reply | Page 12> |
kevin tyler
Old Croc Joined: 15 April 2007 Location: Spain Status: Offline Points: 3402 |
Posted: 19 February 2018 at 11:17am |
Hi guys
I got in to a bit of a discussion on the turbo sound forum about these columns, I suggested that the design of these all in one systems was flawed because some of us with a garage full of subs might like to purchase just the top end and use them with existing gear, someone has suggested that the subs in these rigs are crossing much higher than your shop bought active sub and my argument is negated because there could be a dip of missing output between 80 and 150 cycles, I suggested that if you are using one of these gizmos, it’s unlikely you or the crowd would be that aware of the dip or would be that bothered about it if it was so obvious. I would have thought that regardless of how many 2 or 3 inch speakers you have in the drain pipe, that sub above 120 cycles would sound horrible, What do you guys think ? I’m thinking of splashing out on the new ip3000, just one but wonder would 2 ip2000 be more sensible. Cheers Kev Edited by kevin tyler - 19 February 2018 at 11:18am |
Pasi
Old Croc Joined: 25 April 2010 Location: Knutsford Status: Offline Points: 2732 |
They are correct. Those small drivers barely get down to 150 with any sensible levels and subs must go higher up than usually to meet them. How it sounds, depends on sub itself and how well it is aligned to the tops. I've done tops with 200Hz high pass and sub with 125Hz second order low pass to create smoothly rising response from 200Hz downwards. With correct time alignment it sounded good.
nuclearbass
Old Croc Joined: 06 May 2010 Location: Rotherham Status: Offline Points: 9050 |
Food for thought
Logic have a prototype in world just about ready for touring. It’s a redic loud Column speaker that sits on top of 3 218s 🙈 |
one life - have fun!
Force fusion pro audio |
kevin tyler
Thanks guys.
I stand corrected. Kev |
nuclearbass
V line it’s called |
kevin tyler
Plans ?
Thanks. |
MarjanM
Those are not really small.
smitske96
Young Croc Joined: 16 February 2016 Location: The Netherlands Status: Offline Points: 1092 |
Logic systems site doesn't work
Conanski
Old Croc Joined: 26 January 2006 Location: Ottawa, Canada Status: Offline Points: 2545 |
What are you using it for? I have heard the iP2000 and IMO it sounds decent but I'd need to have a specific use for it before I'd buy one, they don't cluster well the only proper way to use multiples is in a vertical stack and most of these hipster designer things aren't meant to be used that way. Edited by Conanski - 19 February 2018 at 7:53pm |
nuclearbass
They do multiple sizes starting with 3 drivers up to 12
nuclearbass
There not on the site yet I don’t think |
smitske96
I'm still skeptic, it says it will go down to 125 Hz, but will that also be the case at very high levels?
