  New Posts New Posts RSS Feed - Thickness of Curved Section?
chris_k View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote chris_k Quote  Post ReplyReply Direct Link To This Post Topic: Thickness of Curved Section?
    Posted: 21 April 2006 at 9:40am
I`m just about to build some HD215`s and i`m wondering how thick people recommend the curved section to be. I will be pre-laminating  (like Vitor`s), using 4mm ply. Will 3 laminates (12mm) be fine or should i go for 4 (16mm)?
Done a search of the forum but cant really find a good answer.
Cheers
pope View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote pope Quote  Post ReplyReply Direct Link To This Post Posted: 21 April 2006 at 11:51am
Hi!
I think most use 5 pieces like me! 4 could do but not 3! Dom and Vivo use 18 mm ply in 4-5 pieces instead. I think that is better because it is hard to get a full proof laminate. There is always some air between the plys and if its to much it could rattle. If you do like Vitor I dont think it is a problem but you have to put a a lot off effort to it.
mykey View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mykey Quote  Post ReplyReply Direct Link To This Post Posted: 23 April 2006 at 2:15am
 use this! its better and faster.
tobeconfirmed View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tobeconfirmed Quote  Post ReplyReply Direct Link To This Post Posted: 18 May 2006 at 5:39am
any one got any dimensions and angles for a 5piece curved section????
