  New Posts New Posts RSS Feed - This a good price for 4 TSE-118's?
Ajsski99 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ajsski99 Quote  Post ReplyReply Direct Link To This Post Topic: This a good price for 4 TSE-118's?
    Posted: 08 April 2021 at 5:16pm
Hi all,
I got no idea how much these cabs are worth,
Found someone wanting to sell 4 original cabs loaded with Fane 18xb 1000w for £1200
Good deal?
Cheers
Robbo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Robbo Quote  Post ReplyReply Direct Link To This Post Posted: 08 April 2021 at 6:18pm
First of all, 18XB drivers are completely wrong for TSE118 cabinets as the ribbed cones disintegrate under pressure.
Secondly, are you sure that they are original Turbosound cabinets as all of the modern Fane drivers with the black finned heatsink attached will not fit in a TSE118 as the heatsink fouls the loading hatch and prevents it being fitted and screwed down correctly.
There are a lot of copies of TSE118 knocking about so be very wary when buying some.
Boxes-R-Blue View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Boxes-R-Blue Quote  Post ReplyReply Direct Link To This Post Posted: 22 April 2021 at 12:50am
As Robbo Said, Turbosound ceases to be Turbosound the moment someone "upgrades it" those boxes are worth £100 each!
APC321 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote APC321 Quote  Post ReplyReply Direct Link To This Post Posted: 23 April 2021 at 1:14pm
The original driver for the TSE118 (Turbosound LS1802) is quite a modest driver with a 3" voice coil.
Edited by APC321 - 23 April 2021 at 1:14pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Robbo Quote  Post ReplyReply Direct Link To This Post Posted: 23 April 2021 at 1:25pm
Original driver for TSE118 was LS1801 which was the Fane driver then later the mk2 version came along with the LS1802 Precision Devices driver fitted.
They were both identical spec drivers with 300w 3" voice coils except that in real life, the Fane was quite a bit more sensitive than the PD which made mixing and matching a little awkward.
