This is my amp biggest driver it can handle |
Post Reply | Page <12 |
gen0me
Arent you going to use CB1902 on bass?
So why you ask about bridged second amp? |
bob4
Old Croc Joined: 29 February 2004 Location: Finland/Germany Status: Offline Points: 1842 |
devils advocate chipping in What kind of music do you play? If it's house, as your username suggests, a stack of four HD15 would be a good start. Stacking multiples of the same is almost always better than trying to match random subs. It's guaranteed to work without further tweaking. If you are anxious to make a REALLY big noise, buid four HD15s it will not look as impressive as that old coffin though, but your back will thank you later
PS:used to have four measly mdf HD15 loaded with eminence kappas, but was happy enough with them playing jungle and reggae |
Future-House
Registered User Joined: 30 January 2015 Status: Offline Points: 83 |
Hi
Music I'll be playing Hard Tek, Jungle, Breakbeat, PsyTrance, Hardtrance, Had a little gander thru the internet I possibly have found a fane plan, which is close How many sheets isit for 2 HD15s? |
bob4
It's been ages, but I would hazard a guess that it's 1,5 - 2 sheets (assuming 1,2 x 2,4 sheet)
bob4
Just an afterthought, in a squeeze it might be possible to get 4 HD15's built from 3 sheets (do your own math!!!). If just building two, the lumberyard would have to keep almost half a sheet as offcuts, so it might be relatively cheap to go from building 2 to 4.
For the genres you mention, a pile of HD15 will be nice. You can always build some X1s or other subs if you later decide you need a lot of pressure below 40-45 Hz. The jamo tops look big enough in relation to the HD15s. If they are made from decent ply or mdf you could try and salvage them, put in some budget drivers fane or p-audio. You might have to build a new baffle though, especially the 10" drivers are placed very closely to each other, it will likely be hard to just drop in differently shaped drivers. if you have very little funs but would still want to diy some tops, you could just buy a couple of fane 12-250 tc 12" fullrange drivers and build some full range ghetto tops. pros: - no passive crossovers needed - one driver does 100 - 17.000 Hz (yes, that's right!) - only simple two-way active crossover needed cons: - beams at high frequencies
Future-House
Brilliant thanks for your time, big help
